Unofficial File parts/3068bp7e.dat
Part Attributes: Base Part: 3068b.dat
Tile  2 x  2 with Green Monitor Screen, White Switch Button, Dark Bluish Grey Window Pattern
0 Tile 2 x 2 with Green Monitor Screen, White Switch Button, Dark Bluish Grey Window Pattern 0 Name: 3068bp7e.dat 0 Author: Vincent Messenet [Cheenzo] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Tile 0 !KEYWORDS BrickLink 3068pb0851, BrickOwl 922224, Brickset 46502 0 !KEYWORDS Rebrickable 3068bpr0136, Set 31052, Set 31083, Set 31085, Set 31097 0 !KEYWORDS Set 31108, Set 40145, Set 40305, Set 45570, Set 60044, Set 60097 0 !KEYWORDS Set 910002, Set 910009, Set 910023
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bs01.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s01.dat 1 15 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s02.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s03.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s06.dat 1 15 13.7 0 -16.5 1 0 0 0 1 0 0 0 1 4-4disc.dat
None
2026-06-19 20:37:41
Part Reviewer
made the following comment.
2026-06-20 09:19:01
All the yellow areas inside the monitor should actually be the color white?!
posted a vote of Hold
2026-06-22 18:36:10
See above.
Also there are at least 2 variants of this pattern spread across multiple base colours. Please verify you mean the correct one and things which can be re-used.
2026-06-22 18:57:48
2026-06-22 19:25:49
*the dark grey window would technically be colour 16
*I'm beginning to think the dark green areas are a printing error and shouldn't be there...
2026-06-25 14:49:26
*A lot of the triangles in the button area could be merged to quads
*Should the button area become a sub-file?
2026-07-02 19:30:14
Switched from DBG to 16
Applied rectifier
Subfiled button background for reuse in other variants
For the Dark Green I'm not sure but it is in 3068bp72s01 if we need to change it
This part is copyright © Vincent Messenet
