Unofficial File parts/3068bp73.dat
Base Part: 3068b.dat
0 Tile 2 x 2 with Green Monitor Screen, White Button, White Window Pattern
0 Name: 3068bp73.dat
0 !CATEGORY Tile
0 !KEYWORDS BrickLink 3068pb0058, BrickOwl 922224, Brickset 46502
0 !KEYWORDS Rebrickable 3068bpr0095, Set 10128
0 !HISTORY 2026-06-19 [Cheenzo] Subfiled for new pattern, corrected some colours
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bs01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s01.dat
1 15 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s02.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s03.dat
1 15 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s04.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s05.dat
Needs 2 More Votes (F)
None
Vincent Messenet [Cheenzo]
2026-06-19 20:37:40
posted a vote of Hold
2026-06-22 18:37:38
The external links seem incorrect. Or is this the wrong pattern?
made the following comment.
2026-06-22 19:35:31
This should be BL 3068pb0062 not 3068pb0058 assume?
To clarify BL knows 3 variants of this print:
3068pb0021 (Element ID 4206851 "FLAT TILE 2X2 'NO. 98'") - used likely only in 2003 without a plain power button and old grey print
3068pb0062 (Element ID 4289304 "FLAT TILE 2X2 'NO. 137'") - used from ca. 2004-2012-ish, grey power button symbol, bluish grey print
3068pb0381 (not recognized by Lego as a different part) - used from ca. 2012-2020, grey dot power button bluish grey print
2026-06-25 14:19:41
I am even more unsure which one this is meant to be. As far as I can tell only 2 versions with the power button symbol exist:
White print on Dark Bluish Grey part and Dark Bluish Grey print on White part.
From where is the Black symbol one?
2026-07-01 21:07:22
The only notes I have, from back when I made them, is this:
0 // No.95, 46502, 4200902, Dk.Grey, 2003
1 8 -42 0 0 1 0 0 0 1 0 0 0 1 3068bp72.dat
0 // No.95, 46502, 4288298, Dk.St.Grey, 2003-2014
1 72 0 0 0 1 0 0 0 1 0 0 0 1 3068bp72.dat
0 // No.137, 47369, 4289304, White, 2006-2013
1 15 42 0 0 1 0 0 0 1 0 0 0 1 3068bp73.dat
2026-07-01 21:11:16
So then I guess the power button should be changed to Dk. Bluish Grey, this is the 2004-2014 version of the white base part and everything should be fine (except for the external links).
2026-07-01 21:13:27
BL: 3068pb0062
RB: 3068bpr0137
BO: 918388
Lego/Brickset: 4289304/FLAT TILE 2X2 'NO. 137'
RB: 3068bpr0137
BO: 918388
2026-07-02 19:38:21
Corrected colors according to photo from BL
This part is copyright ©
Magnus Forsberg
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
Vincent Messenet
