Unofficial File parts/s/24201s01.dat
~Slope Brick Curved  2 x  1 x  0.667 Inverted - Bottom Part
0 ~Slope Brick Curved 2 x 1 x 0.667 Inverted - Bottom Part 0 Name: s\24201s01.dat 0 Author: Massimo Maso [Sirio] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // Primitives 1 16 0 1 -10 0 0 10 1 0 0 0 1 0 rect.dat 1 16 0 12 30 0 0 10 4 0 0 0 -1 0 rect.dat 1 16 0 10.5 27 7 0 0 0 0 -2.5 0 1 0 rect.dat 1 16 0 4.5 7 -7 0 0 0 0 4.5 0 1 0 rect.dat 1 16 0 1.5 -7 0 0 -7 1.5 0 0 0 -1 0 rect.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 stud2a.dat 1 16 0 8 20 1 0 0 0 1 0 0 0 1 stud2a.dat 1 16 0 6 0 0 0 -7 3 1 0 7 0 0 rect2p.dat 1 16 0 11.5 18.5 -7 0 0 0 1 -1.5 0 0 -8.5 rect3.dat 1 16 0 3.4286 0 0 0 1 0 2.5714 0 -1 0 0 stud2s2.dat 1 16 0 10.7059 20 0 0 1 0 1.0588 0 -1 0 0 stud2s2.dat 1 16 0 0 0 1 0 0 0 3.4286 0 0 0 1 stud2s2e.dat 1 16 0 8 20 1 0 0 0 2.7059 0 0 0 1 stud2s2e.dat 1 16 -10 -24.9719 30 0 1 0 26.9719 0 30.9717 -40 0 40 48\1-8chrd.dat 1 16 10 -24.9719 30 0 -1 0 26.9719 0 30.9717 -40 0 40 48\1-8chrd.dat 1 16 -10 -24.9719 30 0 1 0 26.9719 0 30.9717 -40 0 40 48\1-8edge.dat 1 16 10 -24.9719 30 0 1 0 26.9719 0 30.9717 -40 0 40 48\1-8edge.dat 0 // Faces 3 16 -10 8 10 -10 0 10 -7 8 10 4 16 7 8 10 -7 8 10 -10 0 10 10 0 10 4 16 -7 10 10 -7 8 10 7 8 10 7 10 10 3 16 7 8 10 10 0 10 10 8 10 4 16 7 10 10 7 8 10 7 8 27 7 13 27 4 16 -7 10 10 -7 13 27 -7 8 27 -7 8 10 4 16 -10 8 10 -7 8 10 -7 8 27 -10 8 30 4 16 7 8 27 10 8 30 -10 8 30 -7 8 27 4 16 10 8 10 10 8 30 7 8 27 7 8 10 4 16 -7 3 -7 -7 9 7 -7 0 7 -7 0 -7 4 16 7 0 7 7 9 7 7 3 -7 7 0 -7 4 16 -7 0 -7 -7 0 7 -10 0 10 -10 0 -10 4 16 7 0 7 10 0 10 -10 0 10 -7 0 7 4 16 7 0 -7 10 0 -10 10 0 10 7 0 7 4 16 -7 0 -7 -10 0 -10 10 0 -10 7 0 -7 4 16 10 0 10 10 0 -10 10 2 -10 10 8 10 3 16 10 8 30 10 8 10 10 16 30 3 16 10 16 30 10 8 10 10 2 -10 3 16 -10 8 30 -10 16 30 -10 8 10 3 16 -10 8 10 -10 16 30 -10 2 -10 4 16 -10 2 -10 -10 0 -10 -10 0 10 -10 8 10 0 // Edges 2 24 -7 8 10 -10 8 10 2 24 -7 10 10 -7 8 10 2 24 7 8 10 7 10 10 2 24 -10 0 10 10 0 10 2 24 10 8 10 7 8 10 2 24 7 8 10 7 8 27 2 24 -7 8 27 -7 8 10 2 24 -7 0 7 -7 0 -7 2 24 7 0 -7 7 0 7 2 24 -10 8 30 -10 8 10 2 24 -10 8 10 -10 0 10 2 24 -10 0 10 -10 0 -10 2 24 10 0 -10 10 0 10 2 24 10 0 10 10 8 10 2 24 10 8 10 10 8 30
None
2026-06-17 16:37:03
Subparted
edited the part header.
2026-06-17 19:44:32
Header Edits
description:
~Slope Brick Curved 2 x 1 x 0. 667 Inverted - Bottom Part
to
Comment:
2026-06-21 12:38:10
Moved front lip to Y = 2.
If you like this solution, I will update 24201b01, 32803b01 and so on.
