Unofficial File parts/973d06.dat
View official version of part
Part Attributes: Base Part: 973.dat
Minifig Torso with Football and Danish Flag on Green and White "1" on Back Side Stickers
0 Minifig Torso with Football and Danish Flag on Green and White "1" on Back Side Stickers 0 Name: 973d06.dat 0 Author: Steffen [Steffen] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP This is meant as the generic Entry for all possible Combinations of Sets 3404-3407 0 !HELP For Numbers use 4141242b.dat - 4141242w.dat 0 !HELP For Flags use XY.dat (Y = c, g, k, o, s) for regular Players 0 !HELP For Flags use XY.dat (Y = d, h, l, p, t) for Green Goalkeepers 0 !HELP Replace X with 4141966 for Set 3404 0 !HELP Replace X with 4141967 for Set 3405 0 !HELP Replace X with 4141246 or 4141339 for Set 3406 0 !HELP Replace X with 4141964 for Set 3407 0 BFC CERTIFY CCW 0 !CATEGORY Sticker Shortcut 0 !KEYWORDS Bricklink 973pb0823, Football 2000, Goalie, Player, Set 3404 0 !KEYWORDS Set 3405, Set 3406, Set 3407, Soccer, Team Bus 0 !HISTORY 2017-12-30 [PTadmin] Official Update 2017-01 0 !HISTORY 2024-05-27 [OrionP] Change category to Sticker Shortcut 0 !HISTORY 2024-05-28 [OrionP] Official Update 2024-04 0 !HISTORY 2026-04-28 [Sirio] Changed description: moved "Sticker Rear" to end 0 !HISTORY 2026-05-01 [KnightOfTarenta] Added Front Sticker, changed Description to match
0 // Base Part 1 16 0 0 0 1 0 0 0 1 0 0 0 1 973.dat 0 // Front - Flag 1 16 0 16 -10 1 0 0 0 0 -1 0 1 0 4141964d.dat 0 // Back - Number 1 16 0 2 10 -1 0 0 0 0 -1 0 -1 0 4141242a.dat
None
Massimo Maso [Sirio]
2026-04-29 17:15:56
Rene Rechthaler [Blechtaler]
made the following comment.
2026-04-29 17:20:11
should it be flipped to "Rear Sticker"?
edited the part header.
2026-05-01 10:39:01
Header Edits
description:
Minifig Torso with White "1" on Transparent Background Sticker Rear
to
Minifig Torso with White "1" on Back Side Sticker
Comment:
2026-05-01 10:43:43
Header Edits
keywords:
to
Set 3406, Set 3404, Set 3405, Set 3407, Team Bus, Football 2000, Soccer, Goalee
Comment:
posted a vote of Hold
2026-05-01 10:47:37
Same as on the Torso Assembly Shortcut.
This is incorrect without Front Sticker.
Also there are like 20-ish countries and 22 Numbers, which are theoretically meant to be placed in all possible combinations (>400). I don't think we want to have all of them in the library...
Have this only with a !HELP line allowing for easy exchange of stickers?
Which flag should the front use?
2026-05-01 10:51:37
Header Edits
keywords:
Football 2000, Goalee, Set 3404, Set 3405, Set 3406, Set 3407, Soccer, Team Bus
to
Football 2000, Goalie, Set 3404, Set 3405, Set 3406, Set 3407, Soccer, Team Bus
Comment:
2026-05-01 17:55:25
*added the missing front
*added some !HELP lines to avoid the need to make all the many combinations
*somehow I'd like to rework the back side too and obsolete the old one (wrong dimensions and number can be sub-filed and re-used)
This part is copyright © Steffen
LDraw.org Parts Tracker, Orion Pobursky, Massimo Maso, Chris Böhnke
