Unofficial File parts/s/87544s01.dat
View official version of part
~Panel  1 x  2 x  3 Reinforced without Front Face
0 ~Panel 1 x 2 x 3 Reinforced without Front Face 0 Name: s\87544s01.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2010-12-31 [PTadmin] Official Update 2010-03 0 !HISTORY 2011-08-01 [tchang] Add rounded corners on top, more primitives 0 !HISTORY 2011-12-29 [PTadmin] Official Update 2011-02 0 !HISTORY 2026-04-28 [Blechtaler] complete rework based on 87552s01, original by [Brickaneer]
0 // bottom 1 16 0 68 0 1 0 0 0 -1 0 0 0 1 stud3.dat 0 BFC INVERTNEXT 1 16 0 72 0 16 0 0 0 -4 0 0 0 6 box5.dat 1 16 0 72 0 20 0 0 0 1 0 0 0 -10 recte3.dat 1 16 0 64 -4 20 0 0 0 1 0 0 0 -6 recte3.dat 1 16 0 68 -10 0 0 20 4 0 0 0 1 0 rect2p.dat 4 16 20 72 10 16 72 6 -16 72 6 -20 72 10 4 16 -20 72 10 -16 72 6 -16 72 -6 -20 72 -10 4 16 -20 72 -10 -16 72 -6 16 72 -6 20 72 -10 4 16 20 72 -10 16 72 -6 16 72 6 20 72 10 4 16 -20 72 10 -20 72 -10 -20 64 -10 -20 64 2 4 16 20 72 -10 20 72 10 20 64 2 20 64 -10 0 // inside 0 BFC INVERTNEXT 1 16 0 34 2 16 0 0 0 0 30 0 4 0 box3u4a.dat 1 16 0 4 1 0 0 16 0 -1 0 1 0 0 rect2p.dat 3 16 -20 64 -10 -16 64 2 -20 64 2 3 16 20 64 2 16 64 2 20 64 -10 4 16 -20 64 -10 20 64 -10 16 64 2 -16 64 2 4 16 -16 64 2 -16 64 6 -16 4 6 -16 6 2 4 16 16 6 2 16 4 6 16 64 6 16 64 2 3 16 -16 4 6 -16 4 2 -16 6 2 3 16 16 6 2 16 4 2 16 4 6 0 // reinforcements 0 BFC INVERTNEXT 1 16 -20 6 0 0 4 0 -2 0 0 0 0 2 1-4cylo.dat 1 16 -20 6 0 0 1 0 -2 0 0 0 0 2 1-4ndis.dat 1 16 -16 6 0 0 -1 0 -2 0 0 0 0 2 1-4ndis.dat 0 BFC INVERTNEXT 1 16 16 6 0 0 4 0 -2 0 0 0 0 2 1-4cylo.dat 1 16 16 6 0 0 1 0 -2 0 0 0 0 2 1-4ndis.dat 1 16 20 6 0 0 -1 0 -2 0 0 0 0 2 1-4ndis.dat 1 16 -18 35 2 2 0 0 0 0 29 0 1 0 rect3.dat 1 16 18 35 2 2 0 0 0 0 29 0 1 0 rect3.dat 1 16 0 36 10 20 0 0 0 0 36 0 1 0 recte3.dat 4 16 -20 72 10 -20 64 2 -20 6 2 -20 0 10 4 16 20 64 2 20 72 10 20 0 10 20 6 2 3 16 -20 6 2 -20 4 2 -20 0 10 3 16 -20 0 10 -20 4 2 -20 4 0 3 16 20 0 10 20 4 2 20 6 2 3 16 20 4 0 20 4 2 20 0 10 0 // top 1 16 -18 0 -8 -2 0 0 0 4 0 0 0 -2 1-4cylo.dat 1 16 -18 0 -8 -2 0 0 0 1 0 0 0 -2 1-4chrd.dat 1 16 -18 4 -8 -2 0 0 0 -1 0 0 0 -2 1-4chrd.dat 1 16 18 0 -8 2 0 0 0 4 0 0 0 -2 1-4cylo.dat 1 16 18 0 -8 2 0 0 0 1 0 0 0 -2 1-4chrd.dat 1 16 18 4 -8 2 0 0 0 -1 0 0 0 -2 1-4chrd.dat 1 16 0 2 -10 18 0 0 0 0 2 0 1 0 rect2p.dat 1 16 0 0 1 20 0 0 0 1 0 0 0 9 rect3.dat 4 16 -20 4 0 -16 4 0 -18 4 -10 -20 4 -8 4 16 20 4 -8 18 4 -10 16 4 0 20 4 0 4 16 16 4 0 18 4 -10 -18 4 -10 -16 4 0 2 24 -20 4 -8 -20 4 0 2 24 20 4 -8 20 4 0 4 16 -20 4 0 -20 4 -8 -20 0 -8 -20 0 10 4 16 20 4 -8 20 4 0 20 0 10 20 0 -8 4 16 18 0 -10 20 0 -8 -20 0 -8 -18 0 -10 1 16 0 0 0 1 0 0 0 1 0 0 0 1 stug2-1x2.dat
None
2026-04-28 10:36:56
synchronized the reinforced panels (same structure, same top corners)
all have the top studs included in the subpart (seems to be a relic from the old one which had both variants)
posted a vote of Hold
2026-04-28 15:15:43
Please do a complete rewrite.
made the following comment.
2026-04-28 15:38:19
code is already copied in from 87552s01 and stretched, does that count? they were already very similar before (I guess the tchang edit from 2011 was the same, derived from 87552s01 or vice versa)
2026-04-28 18:20:46
It doesn't matter what has been done previously. You need to rewrite the part.
2026-04-28 20:16:19
took author and license
edited the part header.
2026-04-28 21:01:12
Header Edits
description:
~Panel 1 x 2 x 3 without Front Face and Studs
to
Comment:
2026-04-28 22:48:44
Header Edits
description:
to
Comment:
LDraw.org Parts Tracker, J.C. Tchang
