0 ~Panel 1 x 4 x 3 Reinforced without Front Face
0 Name: s\60581s01.dat
0 !HISTORY 2009-10-13 {LEGO Universe Team} Original part shape
0 !HISTORY 2019-01-25 [Philo] Subparted from Rolf Osterthun initial design
0 !HISTORY 2026-04-28 [Blechtaler] adapted from 87544s01 (with rounded top corners)
0 // bottom
1 16 0 68 0 1 0 0 0 -1 0 0 0 1 stug3-1x3.dat
1 16 0 72 0 36 0 0 0 -4 0 0 0 6 box5.dat
1 16 0 72 0 40 0 0 0 1 0 0 0 -10 recte3.dat
1 16 0 64 -4 40 0 0 0 1 0 0 0 -6 recte3.dat
1 16 0 68 -10 0 0 40 4 0 0 0 1 0 rect2p.dat
4 16 40 72 10 36 72 6 -36 72 6 -40 72 10
4 16 -40 72 10 -36 72 6 -36 72 -6 -40 72 -10
4 16 -40 72 -10 -36 72 -6 36 72 -6 40 72 -10
4 16 40 72 -10 36 72 -6 36 72 6 40 72 10
4 16 -40 72 10 -40 72 -10 -40 64 -10 -40 64 2
4 16 40 72 -10 40 72 10 40 64 2 40 64 -10
0 // inside
1 16 0 34 2 36 0 0 0 0 30 0 4.25 0 box3u4a.dat
1 16 0 4 1 0 0 36 0 -1 0 1 0 0 rect2p.dat
3 16 -40 64 -10 -36 64 2 -40 64 2
3 16 40 64 2 36 64 2 40 64 -10
4 16 -40 64 -10 40 64 -10 36 64 2 -36 64 2
4 16 -36 64 2 -36 64 6.25 -36 4 6.25 -36 6 2
4 16 36 6 2 36 4 6.25 36 64 6.25 36 64 2
3 16 -36 4 6.25 -36 4 2 -36 6 2
3 16 36 6 2 36 4 2 36 4 6.25
0 // reinforcements
1 16 -40 6 0 0 4 0 -2 0 0 0 0 2 1-4cylo.dat
1 16 -40 6 0 0 1 0 -2 0 0 0 0 2 1-4ndis.dat
1 16 -36 6 0 0 -1 0 -2 0 0 0 0 2 1-4ndis.dat
1 16 36 6 0 0 4 0 -2 0 0 0 0 2 1-4cylo.dat
1 16 36 6 0 0 1 0 -2 0 0 0 0 2 1-4ndis.dat
1 16 40 6 0 0 -1 0 -2 0 0 0 0 2 1-4ndis.dat
1 16 -38 35 2 2 0 0 0 0 29 0 1 0 rect3.dat
1 16 38 35 2 2 0 0 0 0 29 0 1 0 rect3.dat
1 16 0 36 10 40 0 0 0 0 36 0 1 0 recte3.dat
4 16 -40 72 10 -40 64 2 -40 6 2 -40 0 10
4 16 40 64 2 40 72 10 40 0 10 40 6 2
3 16 -40 6 2 -40 4 2 -40 0 10
3 16 -40 0 10 -40 4 2 -40 4 0
3 16 40 0 10 40 4 2 40 6 2
3 16 40 4 0 40 4 2 40 0 10
0 // top
1 16 -38 0 -8 -2 0 0 0 4 0 0 0 -2 1-4cylo.dat
1 16 -38 0 -8 -2 0 0 0 1 0 0 0 -2 1-4chrd.dat
1 16 -38 4 -8 -2 0 0 0 -1 0 0 0 -2 1-4chrd.dat
1 16 38 0 -8 2 0 0 0 4 0 0 0 -2 1-4cylo.dat
1 16 38 0 -8 2 0 0 0 1 0 0 0 -2 1-4chrd.dat
1 16 38 4 -8 2 0 0 0 -1 0 0 0 -2 1-4chrd.dat
1 16 0 2 -10 38 0 0 0 0 2 0 1 0 rect2p.dat
1 16 0 0 1 40 0 0 0 1 0 0 0 9 rect3.dat
4 16 -40 4 0 -36 4 0 -38 4 -10 -40 4 -8
4 16 40 4 -8 38 4 -10 36 4 0 40 4 0
4 16 36 4 0 38 4 -10 -38 4 -10 -36 4 0
2 24 -40 4 -8 -40 4 0
2 24 40 4 -8 40 4 0
4 16 -40 4 0 -40 4 -8 -40 0 -8 -40 0 10
4 16 40 4 -8 40 4 0 40 0 10 40 0 -8
4 16 38 0 -10 40 0 -8 -40 0 -8 -38 0 -10
1 16 0 0 0 1 0 0 0 1 0 0 0 1 stug2-1x4.dat
None
description:
~Panel 1 x 4 x 3 with Side Flanges without Front
to
~Panel 1 x 4 x 3 with Side Flanges without Front Face
description:
to
it now also has the same usual wall thickness of 4 LDU
it is now much more in line to the other panels
4x2 s\14718s01.dat
2x2 s\87552s01.dat
2x3 s\87544s01.dat
"Occasionally a part is included with geometry that is not quite correct or the part number itself is incorrect. In this instance, in order to preserve backward compatibility, when a corrected part is made, it's part number will follow these rules and the non-alpha suffix part will be made obsolete."
If you want to update geometry of 60581 which is already official you must submit a new 60581a with updated patterns 60581apxx and shortcuts 60581adxx and obsolete 60581 as well as already official patterns 60581pxx and shortcuts 60581dxx
This part is copyright ©
Philippe Hurbain
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
Rene Rechthaler
all have the top studs included in the subpart (seems to be a relic from the old one which had both variants)
