Unofficial File parts/4740p09.dat
Part Attributes: Base Part: 4740.dat
Dish  2 x  2 Inverted with White Lightning Bolts Pattern
0 Dish 2 x 2 Inverted with White Lightning Bolts Pattern 0 Name: 4740p09.dat 0 Author: Chris Böhnke [KnightOfTarenta] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Baxter Robot Rampage, Baxter Stockman, Bricklink 4740pb008 0 !KEYWORDS BrickOwl 398665, Brickset 13601, energy, Rebrickable 4740pr0015 0 !KEYWORDS Set 79105, Stockman Pod, Teenage Mutant Ninja Turtles, TMNT
0 // Base Part 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\4740s01.dat 0 // Pattern 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\4740p09s01.dat 1 16 0 0 0 0 0 1 0 1 0 -1 0 0 s\4740p09s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\4740p09s01.dat 1 16 0 0 0 0 0 -1 0 1 0 1 0 0 s\4740p09s01.dat
None
2026-04-17 10:24:46
made the following comment.
2026-04-17 10:26:46
Typo... Can someone please rename this to 4740p09.dat ?
renamed the part.
2026-04-17 13:30:57
Gerald Lasser [GeraldLasser]
2026-04-17 15:14:39
Not pertaining to this special pattern but basically all others, I think we shall use a 4-4ering in these patterns to "close" them on prim subst.
I would make the s01 WITH the 4-4ering
and the s00 without
2026-04-17 15:15:20
Would neet to check a render how this will look, But I guess definately better than gaps
2026-04-17 17:11:14
Thanks for renaming!
@Gerald:
So... nothing to change here for now, is that right?
2026-04-17 18:04:08
Correct
This part is copyright © Chris Böhnke
