Unofficial File parts/31074p01.dat
Base Part: 31074.dat
0 Duplo Baseplate 12 x 16 with 12 x 4 Stud Gap with River Pattern
0 Name: 31074p01.dat
0 Author: Bertrand Lequy [Berth]
0 !CATEGORY Baseplate
0 !KEYWORDS Bricklink 31074, Brickowl 619443, Brickset 31074
0 !KEYWORDS Rebrickable 31074pr0001, Set 2604, Set 2605, Set 9194
4 16 -248 0 -168 248 0 -168 248 0 168 -248 0 168
4 16 248 0 -168 320 0 -168 320 0 168 248 0 168
4 16 -320 0 -168 -248 0 -168 -248 0 168 -320 0 168
4 16 -248 0 -240 248 0 -240 248 0 -168 -248 0 -168
4 16 -248 0 168 248 0 168 248 0 240 -248 0 240
1 16 160 0 0 1 0 0 0 1 0 0 0 1 stug20-8x8.dat
1 16 160 0 180 1 0 0 0 1 0 0 0 1 stug20-1x8.dat
1 16 160 0 -180 1 0 0 0 1 0 0 0 1 stug20-1x8.dat
1 16 140 0 220 1 0 0 0 1 0 0 0 1 stug20-1x7.dat
1 16 140 0 -220 1 0 0 0 1 0 0 0 1 stug20-1x7.dat
1 16 -220 0 60 1 0 0 0 1 0 0 0 1 stug20-3x3.dat
1 16 -220 0 180 1 0 0 0 1 0 0 0 1 stug20-3x3.dat
1 16 -220 0 -60 1 0 0 0 1 0 0 0 1 stug20-3x3.dat
1 16 -220 0 -180 1 0 0 0 1 0 0 0 1 stug20-3x3.dat
1 16 -300 0 100 1 0 0 0 1 0 0 0 1 stug20-5x1.dat
1 16 -300 0 -100 1 0 0 0 1 0 0 0 1 stug20-5x1.dat
0 !TEXMAP END
4 16 248 4 168 248 4 -168 -248 4 -168 -248 4 168
4 16 320 4 168 320 4 -168 248 4 -168 248 4 168
4 16 -248 4 168 -248 4 -168 -320 4 -168 -320 4 168
4 16 248 4 -168 248 4 -240 -248 4 -240 -248 4 -168
4 16 248 4 240 248 4 168 -248 4 168 -248 4 240
1 16 248 0 168 72 0 0 0 1 0 0 0 72 48\1-4disc.dat
1 16 -248 0 168 -72 0 0 0 1 0 0 0 72 48\1-4disc.dat
1 16 -248 0 -168 -72 0 0 0 1 0 0 0 -72 48\1-4disc.dat
1 16 248 0 -168 72 0 0 0 1 0 0 0 -72 48\1-4disc.dat
1 16 248 4 168 72 0 0 0 -1 0 0 0 72 48\1-4disc.dat
1 16 -248 4 168 -72 0 0 0 -1 0 0 0 72 48\1-4disc.dat
1 16 -248 4 -168 -72 0 0 0 -1 0 0 0 -72 48\1-4disc.dat
1 16 248 4 -168 72 0 0 0 -1 0 0 0 -72 48\1-4disc.dat
1 16 248 0 168 72 0 0 0 4 0 0 0 72 48\1-4cyli.dat
1 16 -248 0 168 -72 0 0 0 4 0 0 0 72 48\1-4cyli.dat
1 16 -248 0 -168 -72 0 0 0 4 0 0 0 -72 48\1-4cyli.dat
1 16 248 0 -168 72 0 0 0 4 0 0 0 -72 48\1-4cyli.dat
1 16 248 0 168 72 0 0 0 1 0 0 0 72 48\1-4edge.dat
1 16 -248 0 168 -72 0 0 0 1 0 0 0 72 48\1-4edge.dat
1 16 -248 0 -168 -72 0 0 0 1 0 0 0 -72 48\1-4edge.dat
1 16 248 0 -168 72 0 0 0 1 0 0 0 -72 48\1-4edge.dat
1 16 248 4 168 72 0 0 0 1 0 0 0 72 48\1-4edge.dat
1 16 -248 4 168 -72 0 0 0 1 0 0 0 72 48\1-4edge.dat
1 16 -248 4 -168 -72 0 0 0 1 0 0 0 -72 48\1-4edge.dat
1 16 248 4 -168 72 0 0 0 1 0 0 0 -72 48\1-4edge.dat
4 16 -248 4 -240 248 4 -240 248 0 -240 -248 0 -240
4 16 248 4 240 -248 4 240 -248 0 240 248 0 240
4 16 -320 4 168 -320 4 -168 -320 0 -168 -320 0 168
4 16 320 4 -168 320 4 168 320 0 168 320 0 -168
2 24 -248 0 -240 248 0 -240
2 24 -248 4 -240 248 4 -240
2 24 -248 0 240 248 0 240
2 24 -248 4 240 248 4 240
2 24 -320 0 -168 -320 0 168
2 24 -320 4 -168 -320 4 168
2 24 320 0 -168 320 0 168
2 24 320 4 -168 320 4 168
Needs 2 More Votes (N)
Has Uncertified Subfiles
None
2026-01-04 17:09:24
2026-01-05 06:20:32
made the following comment.
2026-01-05 06:24:17
2026-01-05 17:06:53
Such a simple pattern must be possible to make as a vector pattern. Only 2 colours and large areas.
The texmap code could be simplified and use the part instead of copying the whole code.
And if it stay as a texmap, the fallback pattern is missing.
2026-01-05 20:50:38
I choose a texmap because some studs are partially painted. If the pattern were on the plane surface only, I would have used a vector design.
https://rebrickable.com/media/parts/photos/2/31074-2-d7d5877c-eca8-49de-966c-c5363d27dc96.jpg
https://img.bricklink.com/ItemImage/PN/6/31074.png
https://www.steinpalast.eu/media/image/a1/5b/7e/4079_600x600.jpg
Rene Rechthaler [Blechtaler]
2026-03-26 18:52:30
part bottom should be done with box+chrd prims (and in a separate subfile, only the top surface missing, to be reused both here and in unpatterned base -> with studs?)
This part is copyright ©
Bertrand Lequy
Licensed under
CC BY 4.0
The comment I made had not be uploaded:
This is my first attempt with the meta !TEXTMAP, so I may have made errors.
DatHeader wanted me to add FALLBAK command, but wherever I put it, it messed my file up.
