Unofficial File parts/s/2361p03s01.dat
~Baseplate 32 x 32 Road 7-Stud Crossroads with Runway Narrow Pattern - 1/8
0 ~Baseplate 32 x 32 Road 7-Stud Crossroads with Runway Narrow Pattern - 1/8 0 Name: s\2361p03s01.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
1 16 316 0 316 4 0 0 0 1 0 0 0 4 1-8chrd.dat 4 16 165 0 165 320 0 165 320 0 316 318.8284 0 318.8284 4 15 320 0 165 165 0 165 170.234 0 157 320 0 157 3 15 165 0 165 164.0472 0 164.0472 170.234 0 157 4 15 320 0 4 241 0 4 241 0 0 320 0 0 4 7 320 0 4 320 0 157 232 0 141.2416 241 0 4 4 7 241 0 0 241 0 4 232 0 141.2416 232 0 0 4 7 170.234 0 157 184.0688 0 141.2416 232 0 141.2416 320 0 157 1 7 0 0 0 232 0 0 0 1 0 0 0 232 48\5-48tndis.dat 1 15 0 0 0 8 0 0 0 1 0 0 0 8 48\1-8ring28.dat 1 7 0 0 0 224 0 0 0 1 0 0 0 224 48\1-8chrd.dat 1 7 205 0 55 0 0 -50 0 1 0 -50 0 0 48\1-8chrd.dat 1 15 205 0 55 0 0 -50 0 1 0 -50 0 0 48\1-8tang.dat 4 15 215 0 5 205 0 5 205 0 0 215 0 0 4 15 205 0 0 205 0 5 195.055 0 5 181.159 0 0 4 15 195.055 0 5 185.865 0 8.805 175 0 3.04 181.159 0 0 4 15 185.865 0 8.805 176.675 0 12.61 168.472 0 7.396 175 0 3.04 4 15 176.675 0 12.61 169.645 0 19.645 162.574 0 12.574 168.472 0 7.396 3 7 215 0 5 215 0 0 224 0 0 3 7 215 0 5 224 0 0 158.3904 0 158.3904 4 7 169.645 0 19.645 205 0 5 215 0 5 158.3904 0 158.3904 4 7 158.3904 0 158.3904 112 0 112 112 0 0 169.645 0 19.645 3 7 162.574 0 12.574 169.645 0 19.645 112 0 0 3 7 112 0 0 168.472 0 7.396 162.574 0 12.574 3 7 112 0 0 175 0 3.04 168.472 0 7.396 3 7 112 0 0 181.159 0 0 175 0 3.04 1 7 0 0 0 112 0 0 0 1 0 0 0 112 48\1-8ndis.dat 1 15 0 0 0 8 0 0 0 1 0 0 0 8 48\1-8ring13.dat 1 7 0 0 0 104 0 0 0 1 0 0 0 104 48\1-8disc.dat
None
2025-11-21 15:49:20
unshortened the title ("Pattern" was abbreviated and caused errors)
inproved prim usage
fixed t-junk
edited the part header.
2025-11-21 15:50:22
Header Edits
description:
~Baseplate 32 x 32 Road 7-Stud Crossroads with Runway Narrow Pattern - Eighth
to
Comment:
eighth -> 1/8
made the following comment.
2025-11-21 18:01:47
as of now the ring28 isnt properly connected at the corner
(could be fixed by creating a 5-48ring28, but i didnt know if this is worth it)
could now create a small overlap on higher prim subst
