Unofficial File parts/64767px1.dat
Part Attributes: Base Part: 64767.dat
Minifig Head Squidward with Neutral Pattern
0 Minifig Head Squidward with Neutral Pattern 0 Name: 64767px1.dat 0 Author: Jeff Jones [notmaster] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink 64767pb01, Carlo le Calamar, Rebrickable 64767pr0001 0 !KEYWORDS Set 3818, Set 3834, Set 852713, SpongeBob SquarePants
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\64767px1s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\64767px1s01.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\64767s00.dat
None
2025-07-04 09:12:15
forehead lines look abit wonky
2025-07-04 09:43:58
made the following comment.
2025-07-04 14:58:06
Could you please make a "complete" head, without printed surface, to use here instead of the halves and some loose prims?
Call is 64767s00.dat
2025-07-04 15:14:19
should the condlines be moved from s\64767s02.dat?
2025-07-04 15:23:13
Yes, please do that. From s02 to s01.
2025-07-04 15:48:11
posted a vote of Hold
2025-07-04 17:01:13
The "triangles" in this pattern dosen't seem to fit the condlines.
Did you project them on another surface?
2025-07-04 19:50:13
btw should the forehead lines be made symmetrical?
Rene Rechthaler [Blechtaler]
2025-07-04 21:29:45
yes, should be made symmetrical and integrated to the pattern
and there are overlapping triangles from the forehead to the sides...
2025-07-04 21:55:31
This part is copyright © Jeff Jones
