Unofficial File parts/s/stickerback034x064.dat
~Sticker Back  3.4 x  6.4
0 ~Sticker Back 3.4 x 6.4 0 Name: s\stickerback034x064.dat 0 Author: Willy Tschager [Holly-Wood] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // Stickerback for a 68.5 x 127.5 LDU Sticker with a rounded corner 1.5 LDU and 2 LDU distance from the parts edge to be placed on 57895 - Glass for Window 1 x 4 x 6 1 16 62.25 0 32.75 1.5 0 0 0 -.25 0 0 0 1.5 1-4cyli.dat 1 16 -62.25 0 32.75 -1.5 0 0 0 -.25 0 0 0 1.5 1-4cyli.dat 1 16 0 -.25 0 0 0 63.75 0 .25 0 32.75 0 0 box3u12.dat 1 16 62.25 0 -32.75 1.5 0 0 0 -.25 0 0 0 -1.5 1-4cyli.dat 1 16 -62.25 0 -32.75 -1.5 0 0 0 -.25 0 0 0 -1.5 1-4cyli.dat 1 16 62.25 0 32.75 1.5 0 0 0 -1 0 0 0 1.5 1-4chrd.dat 1 16 -62.25 0 32.75 -1.5 0 0 0 -1 0 0 0 1.5 1-4chrd.dat 1 16 62.25 0 -32.75 1.5 0 0 0 -1 0 0 0 -1.5 1-4chrd.dat 1 16 -62.25 0 -32.75 -1.5 0 0 0 -1 0 0 0 -1.5 1-4chrd.dat 4 16 -62.25 0 34.25 62.25 0 34.25 63.75 0 32.75 -63.75 0 32.75 4 16 63.75 0 -32.75 62.25 0 -34.25 -62.25 0 -34.25 -63.75 0 -32.75 4 16 -62.25 0 -34.25 62.25 0 -34.25 62.25 -.25 -34.25 -62.25 -.25 -34.25 4 16 62.25 -.25 34.25 62.25 0 34.25 -62.25 0 34.25 -62.25 -.25 34.25
Awaiting Admin Review (CCN) Awaiting Admin Review (CCN)
User Vote
MagFors Certify
RainbowDolphin Certify
2025-06-30 15:12:59
Substitutes texture with vector
made the following comment.
2025-06-30 15:42:04
Do we really want to have a difference between description and filename? ZxX and XxZ
Why is this orientation choosen? I think the spec says "landscape" is prefered.
If sticker backsides are allowed to be rotated, which should be the default orientation?
2025-06-30 17:07:45
https://www.ldraw.org/article/512.html#sticker_orientation
"Top is defined as either the logical top of a picture, text, etc. or, in the case of more abstract patterns, what the top is when the sticker is applied."
There are just 3 stickers of this size on the PT fitting 57895 - Glass for Window 1 x 4 x 6. This is the logical top.
Rene Rechthaler [Blechtaler]
posted a vote of Hold
2025-06-30 17:19:25
uses cylc, which has 1-4disc prim -> overlaps
needs cyli+chrd
2025-06-30 17:45:28
2025-06-30 19:46:47
That's a valid orientation for the pattern and top surface.
My question is, how should the standardized backside be oriented?
2025-06-30 21:10:53
Not my business. The stickerback is in sync with the current draft since landscape isn't mentioned anywhere.
Orion Pobursky [OrionP]
2025-07-01 01:22:24
@Magnus Gimme a bit to post the final draft and I'll open a thread in the admin team forum
renamed the part.
2025-07-18 09:16:17
edited the part header.
2025-07-19 09:38:02
Header Edits
description:
~Stickerback for Sticker 6.4 x 3.4
to
~Sticker Back 6.4 x 3.4
Comment:
Sanded description
Massimo Maso [Sirio]
2025-07-24 21:47:42
Wrong name and description: it must be 034 x 064.
I could upload the correct version, but it is better to change the part name before.
renamed the part.
2025-07-27 11:04:05
2025-07-27 11:04:25
Pending re-orientation
2025-07-28 22:04:44
2025-07-29 07:51:44
* Why has this been rotated?
2025-07-30 06:26:36
Header Edits
description:
to
~Stickerback 6.4 x 3.4
Comment:
2025-07-30 08:02:25
* I'm asking again: Why has this been rotated?
2025-07-30 10:42:38
"Orientation should follow the general sticker orientation requirements."
https://www.ldraw.org/docs-main/ldraw-org-official-library-standards/sticker-box-standard.html
"... sticker should be oriented such that X value is greater that Z (Landscape)."
2025-07-30 10:44:04
Header Edits
description:
to
~Stickerback 3.4 x 6.4
Comment:
2025-07-31 11:11:48
* When quoting you should at least quote the entire paragraph:
"Sticker patterns should be oriented so that top is aligned with +Z axis.
When in doubt, sticker should be oriented such that X value is greater that Z (Landscape)."
IMHO it is clear where the "logical top of a picture" is. And since there is currently no other sticker of this size on the PT is is also clear to what this sticker back it tight to.
Please restore the original orientation of this sub.
Philippe Hurbain [Philo]
2025-07-31 12:11:36
I would hugely prefer to see all stickerbacks to have a landscape orientation regardless of image or part orientation so that a single stickerback034x064 could be used for sticker 3.4 x 6.4 AND 6.4 x 3.4 !!!
2025-07-31 12:29:08
First usage doesn't dictate the orientation. The standard does.
What's the point in having a standard if we immediately start breaking it?
2025-07-31 12:48:31
* This is perfectly in sync with the standard. Feel free to adjust the standard to your preferences.
BTW the library is full of parts which respond to different standards as we have just recently seen with the origin of some duplo parts:
https://library.ldraw.org/parts/801
https://library.ldraw.org/parts/5468
https://library.ldraw.org/parts/9788
2025-07-31 12:57:48
"When in doubt, sticker should be oriented such that X value is greater that Z (Landscape)."
A sticker back file is top agnostic and therefore should follow the above. I can make that explicit but I felt it redundant.
2025-07-31 13:01:47
* There is no doubt, were the "logical" top of this sticker is.
2025-07-31 13:38:39
Not following a unwritten standard back then, is not a good reason to not follow a written one today.
2025-07-31 13:50:49
Once again, the back doesn't care about what's on the top. Since the top content is unknown, there is "doubt" and the default orientation (landscape) should be used.
To answer my own question, I guess I need to make this more explicit.
cancelled their vote.
2025-08-02 17:23:36
posted a vote of Certify
2025-08-02 20:54:41
2025-08-02 23:46:10
This part is copyright © Willy Tschager
