Unofficial File parts/s/6318649bc01s01.dat
0 ~Sticker 0.6 x 8.5 with Dark Bluish Grey Lines on Black Background (Formed) - Half
0 Name: s\6318649bc01s01.dat
0 !HISTORY 2025-05-10 [Blechtaler] added NOCLIP
0 !HISTORY 2025-07-20 [Blechtaler] used prims
1 16 0 0 -140.25 0 0 .25 -.25 0 0 0 -1 0 48\11-48ring240.dat
1 16 0 0 -152.75 0 0 .25 -.25 0 0 0 1 0 48\11-48ring240.dat
1 16 0 0 -140.25 0 0 60 -60 0 0 0 -12.5 0 48\11-48cyli.dat
4 16 59.484 -7.83 -140.25 59.4893 -7.75 -140.25 59.4893 -7.75 -152.75 59.484 -7.83 -152.75
4 16 59.73185 -7.862625 -152.75 59.484 -7.83 -152.75 59.4893 -7.75 -152.75 59.7372 -7.7823 -152.75
4 16 59.4893 -7.75 -140.25 59.484 -7.83 -140.25 59.73185 -7.862625 -140.25 59.7372 -7.7823 -140.25
3 16 59.7372 -7.7823 -152.75 59.4893 -7.75 -152.75 59.7372 -7.7823 -149.5
3 16 59.7372 -7.7823 -149.5 59.4893 -7.75 -152.75 59.7372 -7.7823 -148.5
4 16 59.7372 -7.7823 -144.5 59.7372 -7.7823 -148.5 59.4893 -7.75 -152.75 59.4893 -7.75 -140.25
3 16 59.7372 -7.7823 -144.5 59.4893 -7.75 -140.25 59.7372 -7.7823 -143.5
3 16 59.7372 -7.7823 -143.5 59.4893 -7.75 -140.25 59.7372 -7.7823 -140.25
5 24 59.73185 -7.862625 -140.25 59.73185 -7.862625 -152.75 58.195475 -15.5927 -152.75 59.7372 -7.7823 -152.75
5 24 59.484 -7.83 -140.25 59.484 -7.83 -152.75 59.4893 -7.75 -152.75 57.954 -15.528 -152.75
0 BFC NOCLIP
4 72 59.7372 -7.7823 -144.5 59.7372 -7.7823 -143.5 59.73185 -7.862625 -143.5 59.73185 -7.862625 -144.5
4 72 59.7372 -7.7823 -149.5 59.7372 -7.7823 -148.5 59.73185 -7.862625 -148.5 59.73185 -7.862625 -149.5
4 0 59.7372 -7.7823 -143.5 59.7372 -7.7823 -140.25 59.73185 -7.862625 -140.25 59.73185 -7.862625 -143.5
4 0 59.7372 -7.7823 -148.5 59.7372 -7.7823 -144.5 59.73185 -7.862625 -144.5 59.73185 -7.862625 -148.5
4 0 59.7372 -7.7823 -152.75 59.7372 -7.7823 -149.5 59.73185 -7.862625 -149.5 59.73185 -7.862625 -152.75
1 0 0 0 -140.25 0 0 60.25 -60.25 0 0 0 -3.25 0 48\11-48cyli.dat
1 72 0 0 -143.5 0 0 60.25 -60.25 0 0 0 -1 0 48\11-48cyli.dat
1 0 0 0 -144.5 0 0 60.25 -60.25 0 0 0 -4 0 48\11-48cyli.dat
1 72 0 0 -148.5 0 0 60.25 -60.25 0 0 0 -1 0 48\11-48cyli.dat
1 0 0 0 -149.5 0 0 60.25 -60.25 0 0 0 -3.25 0 48\11-48cyli.dat
Needs 2 More Votes (F)
Has Uncertified Subfiles
None
Rene Rechthaler [Blechtaler]
2025-05-10 11:09:27
added NOCLIP (transparent stickers on transparent part)
posted a vote of Hold
2025-07-20 15:08:49
Missing 2 surfaces at the closed end.
Excessive condlines. Could be simplified.
made the following comment.
2025-07-20 15:34:07
hm, the part this sticker is attached to is made of prims, should I try to use prims for that too?
(I only edited the NOCLIP in, nothing else)
2025-07-20 17:29:47
used prims
2025-07-20 17:47:56
Don't use cylo prim.
2025-07-20 18:54:37
cylo->cyli
(side prim still broken bc I got the category wrong)
2025-07-20 21:15:04
No, side prim is corrected.
2025-08-26 13:51:23
do I need a stickerback here?
2026-04-05 14:41:57
Is the added extension really needed? It's 0.03 mm long.
It only adds alot of tiny surfaces, and could be replaced by a single quad, at the end of the prim.
2026-04-05 16:26:04
I only used the prims for the main surface, didnt change the end (yet)
should the stickerback be in a separate subfile? with rounded corners or without?
This part is copyright ©
Evert-Jan Boer
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
Rene Rechthaler
