Unofficial File parts/170876cc01.dat
Base Part: 170876c.dat
0 Sticker 0.8 x 3 with Red/Green "Octan" with Black Border on White Background (Formed)
0 Name: 170876cc01.dat
0 !KEYWORDS Bricklink 6335stk01, BrickOwl 592858, Indy Transport, Race, Racing
0 !KEYWORDS Rebrickable 170876, Runaway Truck, Set 6335, town
0 // Sticker Back
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6081b01.dat
0 // Pattern
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\170876cc01s01.dat
1 15 0 0 0 1 0 0 0 1 0 0 0 1 s\170876cc01s02.dat
Needs 2 More Votes (N)
None
2025-01-22 12:17:31
posted a vote of Certify
2025-01-29 16:20:39
Rene Rechthaler [Blechtaler]
2025-03-24 19:53:34
Orion Pobursky [OrionP]
posted a vote of Hold
2025-07-24 03:26:47
Needs a sticker back file.
made the following comment.
2025-07-24 05:59:22
Tend to agree, but how?
There are multiple stickers for this base part, but none cover it whole, nor are these identical in size, shape and position.
2025-08-15 07:34:11
*sub-filed the sticker back (hope this is according to new rules)
An issue has been found with this type of part where stickers clip into the surface on high resolutions. The suggested workaround was to just inline the stickered surface in the shortcut. Shall this be done here?
2025-10-17 21:01:49
Sub-filed the pattern. Since this gets reused for https://library.ldraw.org/parts/43749 and uses quite a bit of lines.
Didn't realize the 2 were identical enough for this back then :S
This part is copyright ©
Chris Böhnke
Licensed under
CC BY 4.0
The instructions have it more down towards to vertical surface (though still slightly touching the curved area); the box and catalogue images have it more centered on the brick. The back of the box also shows an alternate model, where the sticker is more on the flat area. In the end I went for the centered version, as I think it looks better. Not sure if a second formed version can/should be considered here.
For the file itself:
*inlining the logo file caused some ugly triangulation. I added 2 vertices add the border mids to get rid of the most deformed triangles, but it's still not doing much. I'm not sure if these vertices should stay or not.
