Unofficial File parts/3626bpss.dat
Part Attributes: Base Part: 3626b.dat
Minifig Head with SW Moustache, Eyebrows and Small Eyelashes Pattern
0 Minifig Head with SW Moustache, Eyebrows and Small Eyelashes Pattern 0 Name: 3626bpss.dat 0 Author: Evert-Jan Boer [ejboer] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS 20th Anniversary, Bespin, BrickLink 3626pb0214, Cloud City, Home One 0 !KEYWORDS Jabba, Lando Calrissian, Rebrickable 3626bpr0454, Sail Barge 0 !KEYWORDS set 10123, Set 6210, Set 75259, Set 7754 0 !HISTORY 2025-10-19 [KnightOfTarenta] Corrected stud type
0 // Base Part 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626bs02.dat 1 16 0 17 0 0 0 -13 0 -13 0 13 0 0 3-8cyli.dat 1 16 0 17 0 0 0 13 0 -13 0 13 0 0 3-8cyli.dat 0 // Top Area 1 16 0 4 0 -8 0 0 0 -6.4 0 0 0 8 t04o6250.dat 1 16 0 4 0 0 0 8 0 -6.4 0 8 0 0 t04o6250.dat 1 16 0 4 0 8 0 0 0 -6.4 0 0 0 -8 t04o6250.dat 1 16 0 4 0 -8 0 0 0 -6.4 0 0 0 -8 t04o6250.dat 0 // Bottom Area 1 16 0 17 0 8 0 0 0 6.4 0 0 0 8 t04o6250.dat 1 16 0 17 0 0 0 -8 0 6.4 0 8 0 0 t04o6250.dat 1 16 0 17 0 8 0 0 0 6.4 0 0 0 -8 t04o6250.dat 1 16 0 17 0 -8 0 0 0 6.4 0 0 0 -8 t04o6250.dat 0 // Pattern 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626bpsss01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\3626bpsss01.dat
None
Part Reviewer
2025-01-01 10:29:18
posted a vote of Hold
2025-06-06 07:01:15
https://library.ldraw.org/parts/45368 and https://library.ldraw.org/parts/42670 are currently both problematic.
Reason: Stud type changes are typically not regarded and this is the only difference between the two (unless there is a larger difference caused by the re-issue, but than this should be reflected in the part as well, which is curently not the case).
If no difference can be identified and only one version is kept, I would prefer the "b" type version, since this was the first appearance and also the more common one.
Orion Pobursky [OrionP]
renamed the part.
2025-10-19 23:04:35
2025-10-19 23:05:26
Stub needs to changed.
2025-10-19 23:07:38
*changed stud
edited the part header.
2025-10-19 23:08:18
Header Edits
help:
0 !HELP
to
0 !HELP
history:
to
0 !HISTORY 2025-10-20 [KnightOfTarenta] Changed stud from Type C to Type B
Comment:
2025-10-19 23:08:44
Header Edits
history:
to
Comment:
Added edits by Chris
2025-10-19 23:15:46
Header Edits
keywords:
BrickLink 3626pb0214, Lando Calrissian, Rebrickable 3626bpr0454, Set 75259
to
Lando Calrissian, Set 75259, Set 10123, Set 7754, Set 6210, Bespin, Cloud City, Home One, Jabba, Sail Barge, 20th Anniversary, BrickLink 3626pb0214, Rebrickable 3626bpr0454
description:
Minifig Head with Moustache, Eyebrows and Small Eyelashes Pattern
to
Comment:
2025-10-20 06:20:43
Ta
That b-sub is obsolete. You meed to pick another one.
2025-10-20 17:07:33
2025-10-20 17:10:58
U... Next try :S
Jeff Jones [notmaster]
made the following comment.
2026-03-17 22:49:52
bump
LDraw.org Parts Tracker, Chris Böhnke
