Unofficial File parts/6228775u.dat
Sticker  0.8 x  2.5 with Silver Ellipses on Black Background
0 Sticker 0.8 x 2.5 with Silver Ellipses on Black Background 0 Name: 6228775u.dat 0 Author: Gabriel Läufer [Dr.Bricktacular] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink 42083stk01, Brickowl 885585, Bugatti Chiron, Lego Technic 0 !KEYWORDS Rebrickable 38973, set 42083 0 !HISTORY 2025-08-02 [jb70] Using stickerback subfile
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\stickerback008x025.dat 0 // Sticker-Front 1 0 -23.5 -0.25 -6.5 -1.5 0 0 0 1 0 0 0 -1.5 1-4chrd.dat 1 0 23.5 -0.25 -6.5 1.5 0 0 0 1 0 0 0 -1.5 1-4chrd.dat 1 0 23.5 -0.25 6.5 1.5 0 0 0 1 0 0 0 1.5 1-4chrd.dat 1 0 -23.5 -0.25 6.5 -1.5 0 0 0 1 0 0 0 1.5 1-4chrd.dat 1 0 -18.5 -0.25 0 0 0 -3 0 1 0 -3 0 0 2-4chrd.dat 1 0 -18.5 -0.25 0 0 0 -4.5 0 1 0 -4.5 0 0 2-4ndis.dat 1 0 -4.3 -0.25 0 0 0 -1.5 0 1 0 -1.5 0 0 2-4chrd.dat 1 0 18.5 -.25 0 0 0 4.5 0 1 0 -4.5 0 0 2-4ndis.dat 1 0 -4.3 -0.25 0 0 0 -2.25 0 1 0 -2.25 0 0 2-4ndis.dat 1 0 4.3 -0.25 0 0 0 2.25 0 1 0 -2.25 0 0 2-4ndis.dat 1 0 4.3 -0.25 0 0 0 1.5 0 1 0 1.5 0 0 2-4chrd.dat 1 0 18.5 -.25 0 0 0 3 0 1 0 -3 0 0 2-4chrd.dat 1 80 18.5 -.25 0 0 0 1.5 0 1 0 -1.5 0 0 2-4ring2.dat 1 80 -18.5 -.25 0 0 0 -1.5 0 1 0 -1.5 0 0 2-4ring2.dat 1 80 4.3 -.25 0 0 0 .75 0 1 0 -.75 0 0 2-4ring2.dat 1 80 -4.3 -.25 0 0 0 -.75 0 1 0 -.75 0 0 2-4ring2.dat 4 80 -18.5 -.25 4.5 -18.5 -.25 3 18.5 -.25 3 18.5 -.25 4.5 4 80 -18.5 -.25 -3 -18.5 -.25 -4.5 18.5 -.25 -4.5 18.5 -.25 -3 4 80 -4.3 -.25 2.25 -4.3 -.25 1.5 4.3 -.25 1.5 4.3 -.25 2.25 4 80 -4.3 -.25 -1.5 -4.3 -.25 -2.25 4.3 -.25 -2.25 4.3 -.25 -1.5 4 0 4.3 -.25 1.5 -4.3 -.25 1.5 -4.3 -.25 -1.5 4.3 -.25 -1.5 3 0 -18.5 -.25 3 -6.55 -.25 2.25 -4.3 -.25 2.25 4 0 25 -.25 -6.5 25 -.25 6.5 23 -.25 4.5 23 -.25 -4.5 4 0 -23 -.25 4.5 -25 -.25 6.5 -25 -.25 -6.5 -23 -.25 -4.5 3 0 -4.3 -.25 -2.25 -6.55 -.25 -2.25 -18.5 -.25 -3 4 0 -4.3 -.25 2.25 4.3 -.25 2.25 18.5 -.25 3 -18.5 -.25 3 4 0 4.3 -.25 -2.25 -4.3 -.25 -2.25 -18.5 -.25 -3 18.5 -.25 -3 4 0 6.55 -.25 -2.25 18.5 -.25 -3 18.5 -.25 3 6.55 -.25 2.25 4 0 -18.5 -.25 3 -18.5 -.25 -3 -6.55 -.25 -2.25 -6.55 -.25 2.25 3 0 4.3 -.25 2.25 6.55 -.25 2.25 18.5 -.25 3 3 0 6.55 -.25 -2.25 4.3 -.25 -2.25 18.5 -.25 -3 4 0 18.5 -.25 4.5 23 -.25 4.5 25 -.25 6.5 23.5 -.25 8 4 0 -18.5 -.25 4.5 18.5 -.25 4.5 23.5 -.25 8 -23.5 -.25 8 4 0 -23 -.25 4.5 -18.5 -.25 4.5 -23.5 -.25 8 -25 -.25 6.5 4 0 25 -.25 -6.5 23 -.25 -4.5 18.5 -.25 -4.5 23.5 -.25 -8 4 0 23.5 -.25 -8 18.5 -.25 -4.5 -18.5 -.25 -4.5 -23.5 -.25 -8 4 0 -23.5 -.25 -8 -18.5 -.25 -4.5 -23 -.25 -4.5 -25 -.25 -6.5
None
Part Reviewer
2024-12-18 18:52:08
made the following comment.
2024-12-19 08:04:08
Looking good so far.
A minor nitpick would be that T-junc caused by the disc prims is sometimes adressed and sometimes not. Some probably would not mind in this case, but usually it's better to have the T-junc removed.
Rene Rechthaler [Blechtaler]
2024-12-19 16:35:50
using 2-4chrd instead of 2-4disc can help for that (to get rid of the center vertex)
they are otherwise identical
Jens Brühl [jb70]
Part Author
2025-08-03 17:19:21
I used a new stickerback subfile and changed dimensions from 0.8 x 2.8 to 0.8 x 2.5 which I measured on my stickersheet.
Jens Brühl [jb70]
Part Author
2025-08-03 17:25:13
Used 2-4chrd. Again what learned!
Peter Blomberg [WUIt]
2025-11-21 23:35:44
One could simplify the pattern a bit:
1 80 18.5 -.25 0 0 0 1 0 1 0 -1 0 0 2-4ring3.dat
1 80 18.5 -.25 0 0 0 .5 0 1 0 -.5 0 0 2-4ring8.dat
1 5 18.5 -.5 0 0 0 1.5 0 1 0 -1.5 0 0 2-4ring2.dat
1 80 4.3 -.25 0 0 0 .5 0 1 0 -.5 0 0 2-4ring3.dat
1 80 4.3 -.25 0 0 0 .25 0 1 0 -.25 0 0 2-4ring8.dat
1 5 4.3 -.5 0 0 0 .75 0 1 0 -.75 0 0 2-4ring2.dat
This would reduce the number of surfaces that need to be rendered.
Jens Brühl [jb70]
Part Author
2025-12-01 20:13:05
I simplified the rings as suggested by Peter.
This part is copyright © Gabriel Läufer
LDraw.org Parts Tracker, Jens Brühl
