Unofficial File parts/4707c06.dat
Part Attributes: Base Part: 4707.dat
~Electric 12 Volt: Remote Control - Bottom with Front Plugs and Cover with 3 Holes
0 ~Electric 12 Volt: Remote Control - Bottom with Front Plugs and Cover with 3 Holes 0 Name: 4707c06.dat 0 Author: Javier Orquera [kuramapika1] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !PREVIEW 16 0 0 0 -1 0 0 0 1 0 0 0 -1 0 !HISTORY 2025-04-24 [kuramapika1] Added plugs and new 4701c.dat file 0 !HISTORY 2025-09-13 [kuramapika1] Added preview metacommand
1 16 0 0 0 1 0 0 0 1 0 0 0 1 4707b.dat 1 494 -69.5 20.5 12.5 0 0 1 0 1 0 1 0 0 u9654.dat 1 494 -69.5 20.5 47.5 0 0 1 0 1 0 1 0 0 u9654.dat 1 494 -30 20.5 88.5 1 0 0 0 -1 0 0 0 -1 u9654.dat 1 494 -10 20.5 88.5 1 0 0 0 -1 0 0 0 -1 u9654.dat 1 494 65.5 20.5 47.5 0 0 -1 0 1 0 1 0 0 u9655.dat 1 494 65.5 20.5 12.5 0 0 -1 0 1 0 1 0 0 u9655.dat 1 16 0 0 80 1 0 0 0 1 0 0 0 1 4710c.dat
Certified (ACCN) Certified (ACCN)
User Vote
OrionP Admin Review
MagFors Certify
RainbowDolphin Certify
Part Author
2024-10-30 14:19:50
The files are done as stated in the forums and for testing purposes ONLY.
If reviewers are OK with this, can substitute the equivalent one.
On the contrary, please, flag for deletion.
renamed the part.
2024-10-30 16:49:29
edited the part header.
2024-10-30 16:52:06
Header Edits
type:
Shortcut
to
Shortcut
description:
to
Comment:
This assy should be used in 4707c01, 4707c02 and 4707c03
Part Author
made the following comment.
2024-10-30 17:59:25
Why use this in 4707c01? It become the same as 4707c07, with their header differences.
2024-10-30 18:21:13
4707c01 should use 4707c06 + 4708p01 +4709p01
4707c02 should use 4707c06 + 4708p04 +4709p04
4707c03 should use 4707c06 + 4708p05 +4709p05
All three use the same bottom part, containing bottom, plugs and cover.
Forget 4707c07 for now. It needs a complete rework. It is totally wrong now.
Part Author
2025-05-14 18:30:47
Error are fixed. Did some other corrections.
Part Author
2025-09-15 19:46:52
posted a vote of Certify
2025-09-25 11:23:56
2025-09-27 11:07:55
Orion Pobursky [OrionP]
posted a vote of Admin Review
2026-07-08 01:25:46
This part is copyright © Javier Orquera
