Unofficial File parts/43418p01-f1.dat
Part Attributes: Base Part: 43418-f1.dat
Minifig Torso with Yellow Arms with Integral Hand (Down Position) Pattern
0 Minifig Torso with Yellow Arms with Integral Hand (Down Position) Pattern 0 Name: 43418p01-f1.dat 0 Author: Jeff Jones [notmaster] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP Up position arm angle: 75° 0 BFC CERTIFY CCW 0 !KEYWORDS basketball, Bricklink 973bc01, NBA, Rebrickable 973b01, Set 10121-1 0 !HISTORY 2024-10-25 [notmaster] modified from 43370c01-f1.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 43370.dat 1 14 -15.552 9 0 .985 -.17 0 .17 .985 0 0 0 1 43368.dat 1 14 15.552 9 0 .985 .17 0 -.17 .985 0 0 0 1 43369.dat
None
2024-10-25 10:20:34
don't know if part number is correct
renamed the part.
2025-07-13 06:11:03
renamed the part.
2025-07-13 06:17:45
Manfred Schaefer [Lego-Manfred]
Part Author
made the following comment.
2025-07-15 20:51:09
Why was 43370c01p01-f1.dat c01 inserted here and not in 76382px3.dat?
Both parts consist of several individual parts. And both are upper parts.
2025-07-15 21:06:51
76382 is an assembly number. 43370 isn't.
43370 is the torso number and since we don't know the assy number on it, with arms, we have to use the c01-suffix.
2025-07-15 21:37:40
43418 is the assembly number for NBA torsos.
https://brickset.com/sets/3561-1/NBA-Collectors-2
Rene Rechthaler [Blechtaler]
2025-07-15 21:45:35
should the other arm color (brown/nougat) combinations also get added?
(ok these officially dont have an unprinted torso variant)
2025-07-15 21:54:41
We dont make that decision for the regular torso, so I'd say no.
Orion Pobursky [OrionP]
2025-07-16 00:27:18
Joshua had the torso assembly number so renumber imminent.
2025-07-16 05:44:39
With or without the head?
2025-07-16 05:51:42
I think this number is correct, if we don't want to include the head.
2025-07-16 12:58:21
I don't have a problem with no head. Regular torsos used to have the head and we leave it out of the shortcut there.
2025-07-16 13:27:06
i would like to the nba jersey patterns here but unfortunably they are mostly filled with complex gradients :(
renamed the part.
2025-07-16 14:18:21
edited the part header.
2025-07-16 14:26:05
Header Edits
description:
to
Comment:
2025-07-16 14:33:50
also there is id 46340 for weak (2 silver springs) legs and 46418 for strong (1 silver spring and 1 thick yellow spring)
2025-07-17 10:38:13
43418p0?
This part is copyright © Jeff Jones
