Unofficial File parts/4707c05.dat
Part Attributes: Base Part: 4707.dat
Electric 12 Volt: Remote Control for Signal Type 2
0 Electric 12 Volt: Remote Control for Signal Type 2 0 Name: 4707c05.dat 0 Author: Steffen [Steffen] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP Rotate keys by 3.5 degree to pressed down position. 0 BFC CERTIFY CCW 0 !KEYWORDS BrickLink 4707pb04, Set 5081, Set 7860, switch, Train 0 !PREVIEW 16 0 0 0 -1 0 0 0 1 0 0 0 -1 0 !HISTORY 2011-07-25 [PTadmin] Official Update 2011-01 0 !HISTORY 2024-10-12 [kuramapika1] Complete Rework 0 !HISTORY 2024-10-31 [MagFors] Replacing u9004c01 and u9004c02 0 !HISTORY 2025-09-13 [kuramapika1] Adjusted to new parts origin's and added preview metacommand
1 16 0 0 0 1 0 0 0 1 0 0 0 1 4707c08.dat 1 16 42.5 18 65 1 0 0 0 1 0 0 0 1 4708p02.dat 1 16 -42.5 18 65 1 0 0 0 1 0 0 0 1 4709p02.dat
Certified (ACCN) Certified (ACCN)
User Vote
OrionP Admin Review
MagFors Certify
RainbowDolphin Certify
Javier Orquera [kuramapika1]
Part Author
2024-10-23 21:02:36
To P. T. Admin: do what is needed.
Part Author
2024-10-23 21:13:10
Wrong code; fixed now.
edited the part header.
2024-10-26 15:51:36
Header Edits
type:
Shortcut
to
Shortcut
Comment:
Part Author
2024-10-29 19:49:31
Minor corrections in 4707s01.dat and 4707.dat
Part Author
2024-10-29 20:31:52
Moved male and side female plugs to part 4707.dat.
Part Author
2024-10-30 19:56:20
Adapted to new structure using new files.
2024-10-31 20:19:17
Header Edits
type:
Shortcut
to
Shortcut
history:
to
0 !HISTORY 2024-10-31 [MagFors] Renumbered from u9005c01
keywords:
to
Set 5081, Set 7860, Train, switch
Comment:
Updated history
renamed the part.
2024-10-31 20:46:39
2024-10-31 20:49:02
Header Edits
type:
Shortcut
to
Shortcut
history:
to
keywords:
to
Comment:
Updated history
2024-11-01 16:33:19
Header Edits
type:
Shortcut
to
Shortcut
keywords:
to
Comment:
renamed the part.
2024-11-02 07:48:41
Steffen [Steffen]
posted a vote of Hold
2025-01-02 18:28:01
what is the relation between this file and 70028.dat ? Duplicates?
Steffen [Steffen]
cancelled their vote.
2025-01-09 02:21:06
To not create too much hassle here, I retract my hold vote and let you proceed as you think reasonable.
I am ok with you taking over authorship from my file, obsoletizing my previous implementation, renumbering and creating 2 variants.
However, I think that the decision to obsoletize my previous version was wrong, as the geometry has not incompatibly changed. The proper way would have
been to simply add details and document that with a !HISTORY line. That said, go ahead. I myself currently have no time+energy to spend here.
Part Author
2025-09-15 19:46:52
posted a vote of Certify
2025-09-25 11:27:31
2025-09-27 11:09:48
2025-09-27 19:15:44
Header Edits
help:
0 !HELP
to
Comment:
2025-09-27 22:02:13
Origin can't be changed. Need to be moved back to the same as the official 4707c01 have.
Willy Tschager [Holly-Wood]
made the following comment.
2025-09-28 08:00:37
Since when you cannot change an origin? The technique is called "Moveto".
2025-09-28 19:23:43
2025-09-28 20:09:22
Header Edits
description:
to
Electric 12 Volt: Remote Control for Signal Type 1
Comment:
2025-09-28 20:13:47
Header Edits
description:
to
Comment:
2026-06-30 21:05:03
Orion Pobursky [OrionP]
posted a vote of Admin Review
2026-07-08 01:25:05
This part is copyright © Steffen
LDraw.org Parts Tracker, Javier Orquera, Magnus Forsberg
