Unofficial File parts/4708p04.dat
Part Attributes: Base Part: 4708.dat
~Electric Switch: Key Right with Yellow Triangle Up Pattern
0 ~Electric Switch: Key Right with Yellow Triangle Up Pattern 0 Name: 4708p04.dat 0 Author: Javier Orquera [kuramapika1] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP to put this part into a pressed-down state, rotate it 4.3 degrees 0 !HELP around the x-axis 0 BFC CERTIFY CCW 0 !KEYWORDS Set 4707pb03, switch, Train 0 !HISTORY 2025-09-13 [kuramapika1] Adjusted to new primitive origin's
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\4709s01.dat 4 16 -26.5 -7 -4.25 -26.5 -5.5 -4.25 -26.5 -5.5 -5.25 -26.5 -7 -5.25 4 16 -26.5 -7 -5.25 -26.5 -5.5 -5.25 -36.5 -5.5 -5.25 -36.5 -7 -5.25 2 24 -26.5 -5.5 -5.25 -26.5 -7 -5.25 2 24 -26.5 -7 -5.25 -26.5 -7 -4.25 4 16 -42.5 -27 -5.25 -33.25 -27 -11.95 18.9 -27 -11.95 37.5 -27 -5.25 4 16 -33.25 -27 -88.4 -33.25 -27 -11.95 -42.5 -27 -5.25 -42.5 -27 -165.25 4 16 -33.25 -27 -88.4 -42.5 -27 -165.25 37.5 -27 -165.25 18.9 -27 -88.4 4 16 37.5 -27 -165.25 37.5 -27 -5.25 18.9 -27 -11.95 18.9 -27 -88.4 3 14 -7.175 -27 -46.2 -25 -27 -78.5 10.65 -27 -78.5 4 0 -33.25 -27 -88.4 -25 -27 -78.5 -7.175 -27 -46.2 -33.25 -27 -11.95 4 0 10.65 -27 -78.5 18.9 -27 -88.4 18.9 -27 -11.95 -7.175 -27 -46.2 3 0 -7.175 -27 -46.2 18.9 -27 -11.95 -33.25 -27 -11.95 4 0 -33.25 -27 -88.4 18.9 -27 -88.4 10.65 -27 -78.5 -25 -27 -78.5 4 16 -10.5 -23 -100 -10.5 -20 -100 -1.5 -20 -100 -1.5 -23 -100 4 16 -10.5 -20 -96 -10.5 -23 -96 -1.5 -23 -96 -1.5 -20 -96 4 16 -10.5 -20 -100 -10.5 -23 -100 -10.5 -23 -96 -10.5 -20 -96 4 16 -1.5 -23 -96 -1.5 -23 -100 -1.5 -20 -100 -1.5 -20 -96 1 16 -10.5 -20 -98 0 9 0 0 0 2 2 0 0 2-4cylo.dat 1 16 -10.5 -20 -98 0 1 0 0 0 2 2 0 0 2-4chrd.dat 1 16 -1.5 -20 -98 0 -1 0 0 0 2 2 0 0 2-4chrd.dat 2 24 -1.5 -20 -100 -1.5 -23 -100 2 24 -10.5 -23 -96 -10.5 -23 -100 2 24 -10.5 -20 -100 -10.5 -23 -100 2 24 -1.5 -23 -96 -1.5 -20 -96 2 24 -10.5 -23 -100 -1.5 -23 -100 2 24 -1.5 -23 -96 -10.5 -23 -96 2 24 -1.5 -23 -100 -1.5 -23 -96 2 24 -10.5 -23 -96 -10.5 -20 -96
Certified (ACCN) Certified (ACCN)
User Vote
OrionP Admin Review
MagFors Certify
RainbowDolphin Certify
Part Author
2024-10-23 21:00:58
To P. T. Admin: do what is needed.
Part Author
2024-10-25 14:26:27
Deleted History.
Part Author
2024-10-29 19:46:15
Part Author
2025-09-15 19:48:36
posted a vote of Certify
2025-09-25 11:30:26
2025-09-27 11:04:29
Orion Pobursky [OrionP]
posted a vote of Admin Review
2026-07-08 01:26:22
This part is copyright © Javier Orquera
