Unofficial File parts/3005d08.dat
Part Attributes: Base Part: 3005.dat
Brick 1 x 1 with White Rectangle Sticker
0 Brick 1 x 1 with White Rectangle Sticker 0 Name: 3005d08.dat 0 Author: Gabriel Läufer [Dr.Bricktacular] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Sticker Shortcut 0 !KEYWORDS Batmobile (1989), Bricklink 3005pb050, Set 76139 0 !KEYWORDS Tim Burton's Batman
0 // Sticker-Base 1 16 0 0 0 1 0 0 0 1 0 0 0 1 3005.dat 0 // Sticker 1 16 0 12 -10 1 0 0 0 0 -1 0 1 0 6280006m.dat
Not releaseable Errors Found (CCHN) Errors Found (CCHN)
User Vote
OrionP Hold
GeraldLasser Certify
RainbowDolphin Certify
Part Reviewer
2024-10-20 21:12:39
posted a vote of Hold
2024-10-20 21:48:35
Any reason for picking d10 as pattern code?
After d01-d09 comes d0a-d0z, not d10.
d08 is not used.
We should renumber this.
Orion Pobursky [OrionP]
renamed the part.
2024-10-20 23:32:00
cancelled their vote.
2024-10-21 15:57:18
This is a very odd usage.
The backside of this sticker is the "pattern" that create a white surface, viewed through the trans yellow brick.
Does it need to be bfc noclip?
Or do we hard code it, to have a white backside, in this shortcut?
Part Reviewer
made the following comment.
2024-10-26 08:58:04
For those who wants to have a closer look how the sticker is used: Instruction page 268 e.g. step 389 or speeedbuild at min 07:30 (https://www.youtube.com/watch?v=fM1Gw1UM6-4). I would tend to white backside.
Gerald Lasser [GeraldLasser]
posted a vote of Certify
2025-02-18 13:50:04
2025-02-18 14:32:17
2025-03-14 18:37:51
"Does it need to be bfc noclip?
Or do we hard code it, to have a white backside, in this shortcut? "
I'd say both.
Rene Rechthaler [Blechtaler]
2025-06-16 20:39:33
I would say hardcoding white is enough, doesnt look like a transparent sticker sheet...
2025-06-16 21:03:52
Definitely needs to be hardcoded white.
I checked with the Library's 3D viewer and no NOCLIP is fine. How does LDView behave without NOCLIP? If it's fine then no NOCLIP needed.
2025-06-16 21:26:46
I couldn't tell any difference here, if NOCLIP is used or not in LDView, but it still looks awkward in both cases if the back isn't white.
This part is copyright © Gabriel Läufer
