Unofficial File parts/2335dx1.dat
Part Attributes: Base Part: 2335.dat
Flag  2 x  2 with Blue and Yellow Rectangle Sticker
0 Flag 2 x 2 with Blue and Yellow Rectangle Sticker 0 Name: 2335dx1.dat 0 Author: Eugen [app4soft] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Sticker Shortcut 0 !KEYWORDS K (Kilo), Krusty Krab, Set 3833, SpongeBob, Ukraine
1 16 0 0 0 1 0 0 0 1 0 0 0 1 2335.dat 1 16 2 20 30 0 -1 0 0 0 -1 1 0 0 4538725d.dat
Not releaseable Errors Found (HHN) Errors Found (HHN)
User Vote
Holly-Wood Hold
KnightOfTarenta Hold
Eugen [app4soft]
Part Author
2024-10-08 21:46:34
These are files for 2335pb024 part (as presented in official 3825 and 3833 sets), splitted into its 2 subsets and 2 stickers accordingly to sets.
I'm releasing it under CC0 (Public Domain), but due to PT actually not implemented it yet, set license to CC BY 4.0, which should be switched to CC0 once PT would implemented it.
Eugen [app4soft]
Part Author
2024-10-08 21:55:55
Fix previously uploaded files
renamed the part.
2024-10-09 15:05:34
edited the part header.
2024-10-09 15:18:12
Header Edits
description:
=Flag 2 x 2 with Blue and Yellow Rectangle Pattern (Sticker)
to
Comment:
posted a vote of Hold
2024-10-09 15:26:58
Why are you using Flag 11055? Is that the correct part used in this set?
If so, then this needs to be renumberd again to 11055dx1.
Two parts can't have the same description. They need to be different.
Any suggestion to how to tell these apart?
This can't be an alias part, if it is using a different sticker. And "Unofficial_Shortcut Alias" doesn't exist.
So how do we handle this duplication?
made the following comment.
2024-10-09 15:32:19
Or is "Unofficial_Shortcut Alias" a valid parttype?
Eugen [app4soft]
Part Author
2024-10-09 21:29:27
Anyway, lets for now it will use 2335.dat
2024-10-09 21:38:58
I think this duplicate file should be unified into 2335dx0, with two set-number described in keywords line.
It would be far more useful to allocate 2335dx1-dx3 for three other flag sticker shortcuts in these sets.
Please see:
https://library.ldraw.org/official/4777
Gerald Lasser [GeraldLasser]
2024-10-09 22:40:15
I agree with Takeshi, I would even add the sticker sheet number in the keywords
Eugen [app4soft]
Part Author
2024-10-09 22:48:47
"I would even add the sticker sheet number in the keywords", if two flags would be combined into one, there should be two stickers numbers in keywords too, I guess.
And what about two stickers? Both look the same, but they really printed on different paper sheets.
Eugen [app4soft]
Part Author
2024-10-09 22:52:20
"Please see: https://library.ldraw.org/official/4777",— should be "!KEYWORDS Bricklink 2335pb024" added to this part too?
2024-10-10 03:18:22
Yes, external reference should be included if available. This change can be done by admin edit, you don't need to resubmit.
Eugen [app4soft]
Part Author
2024-10-15 17:09:54
Anything need to edit for this part?
Willy Tschager [Holly-Wood]
2024-10-15 17:48:05
This is just bloat.
Jeff Jones [notmaster]
2025-01-20 18:49:24
maybe merge this and the other one
2026-05-27 16:43:20
Pretty sure this doesn't exist at all. Lego.com lists 11055 as base part; also the two sticker sheets seem to be slightly different - the older set has sharp corners, the newer one round corners.
This part is copyright © Eugen
