Unofficial File parts/4614385g.dat
Sticker  1.8 x  1.8 Round with Black Atlantis Trident
0 Sticker 1.8 x 1.8 Round with Black Atlantis Trident 0 Name: 4614385g.dat 0 Author: Evert-Jan Boer [ejboer] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS BrickLink 7985stk01, Brickowl 816737, City of Atlantis 0 !KEYWORDS Rebrickable 94346, Set 7985
1 16 0 0 0 18 0 0 0 -0.25 0 0 0 18 4-4cylc3.dat 1 4 0 -.25 0 18 0 0 0 1 0 0 0 18 4-4ering.dat 1 0 0 -.25 0 1 0 0 0 1 0 0 0 1 logo-atlantis-trident.dat 1 4 0 -.25 0 1 0 0 0 1 0 0 0 1 logo-atlantis-trident-box.dat 4 4 0 -.25 18 -6.8886 -.25 16.6302 -7 -.25 11 7 -.25 11 4 4 6.8886 -.25 16.6302 0 -.25 18 7 -.25 11 12.7278 -.25 12.7278 4 4 16.6302 -.25 6.8886 12.7278 -.25 12.7278 7 -.25 11 18 -.25 0 4 4 18 -.25 0 7 -.25 11 7 -.25 -10.3 16.6302 -.25 -6.8886 4 4 12.7278 -.25 -12.7278 16.6302 -.25 -6.8886 7 -.25 -10.3 6.8886 -.25 -16.6302 4 4 6.8886 -.25 -16.6302 7 -.25 -10.3 1.4 -.25 -15.9 0 -.25 -18 4 4 0 -.25 -18 1.4 -.25 -15.9 -1.4 -.25 -15.9 -6.8886 -.25 -16.6302 4 4 -6.8886 -.25 -16.6302 -1.4 -.25 -15.9 -7 -.25 -10.3 -12.7278 -.25 -12.7278 4 4 -16.6302 -.25 -6.8886 -12.7278 -.25 -12.7278 -7 -.25 -10.3 -18 -.25 0 4 4 -18 -.25 0 -7 -.25 -10.3 -7 -.25 11 -16.6302 -.25 6.8886 4 4 -12.7278 -.25 12.7278 -16.6302 -.25 6.8886 -7 -.25 11 -6.8886 -.25 16.6302
None
Part Reviewer
2024-10-05 18:24:56
posted a vote of Certify
2025-08-07 15:28:30
Rene Rechthaler [Blechtaler]
made the following comment.
2025-08-07 17:36:02
why 1.7 x 1.7 when the base is R18?
1 16 0 0 0 18 0 0 0 -0.25 0 0 0 18 48\4-4cylc3.dat
should the title get corrected? (headeredit)
2025-08-07 17:38:34
also misses the outer connection, should use 1-8chrd...
maybe use a half subfile?
edited the part header.
2025-08-07 18:32:44
Header Edits
description:
Sticker 1.7 x 1.7 Round with Black Atlantis Trident
to
Comment:
2025-08-07 19:13:12
to get an equal rim, I would suggest to scale the subpart to R10LDU and then scale it here x1.8 and in the 6451155a.dat x2.8
it could even use standard res in the subfile, the 6451155a.dat gets an additional aring...
2025-08-07 21:49:53
It looks good to me, as it is made now.
Gerald Lasser [GeraldLasser]
posted a vote of Hold
2025-08-08 08:40:16
Please use 1-8 and 1-4 chrds to properly pad the pattern into the circle
2025-10-19 23:31:11
*bottom of trident misses an edge
*center tip of trident needs to be sharper
*why orient vertically? The real part has it at roughly 45 degree (needs to be measured likely)
*could be sub-filed to reuse for the color-inverted version in Set 8075
*I didn't check the entire Atlantis line, but it appears in multiple sets I'd say. Should the logo become a prim?
Orion Pobursky [OrionP]
2025-10-25 00:45:06
"*why orient vertically? The real part has it at roughly 45 degree (needs to be measured likely)"
This orientation is per spec. IF the real part has it rotated then it should be rotated on the shortcut.
2025-10-25 02:22:33
Are you referring to this line of the spec (I couldn't find any other)?
"Top is defined as either the logical top of a picture, text, etc. or, in the case of more abstract patterns, what the top is when the sticker is applied."
My argument would be:
While it could be argued that the "logical" orientation of the trident would be upright, it contradicts the "applied" form. And this shape is technically a logo, not a "full trident".
This might be a redundant discussion, but I think in terms of geometry and rounding errors, having the base orientation match the applied version will cause less issues.
Should this be discussed in the forums?
2025-10-25 02:23:30
Also it is printed on the sheet with 45 degree angle relative to the sheet's borders.
2025-10-25 02:37:18
It hurts nothing to have the icon aligned to the axes. This is the correct orientation. How it's printed is irrelevant.
2025-10-25 02:42:22
Ok I'll take it back - I found this 59231pb03 having the logo upright.
This pattern still has other issues though.
2025-12-05 16:03:26
I see no reason for having a hi-res back side.
2025-12-05 19:42:43
yes, just subfile the logo and use (normal res) prims outside
Part Reviewer
2025-12-17 20:32:46
modified pattern and put in in logo prims
Part Reviewer
2025-12-17 20:33:45
