Unofficial File parts/3897d01.dat
View official version of part
Part Attributes: Base Part: 3897.dat
Roadsign Wide Rectangle with Black Train Logo Stickers
0 Roadsign Wide Rectangle with Black Train Logo Stickers 0 Name: 3897d01.dat 0 Author: J.C. Tchang [tchang] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Sticker Shortcut 0 !KEYWORDS 9V Trains, Bricklink x53pb01, Metro station, Rebrickable 164555 0 !KEYWORDS Set 4554 0 !HISTORY 2013-12-23 [PTadmin] Official Update 2013-02 0 !HISTORY 2024-05-27 [OrionP] Change category to Sticker Shortcut 0 !HISTORY 2024-05-28 [OrionP] Official Update 2024-04 0 !HISTORY 2026-04-28 [Sirio] Changed description: moved "Sticker" to end; certified CCW 0 !HISTORY 2026-05-09 [KnightOfTarenta] Using correct Sticker File
1 16 0 0 0 1 0 0 0 1 0 0 0 1 3897.dat 1 16 0 -76 -2 1 0 0 0 0 -1 0 1 0 164555a.dat 1 16 0 -76 2 -1 0 0 0 0 -1 0 -1 0 164555a.dat
None
2024-08-07 13:35:33
posted a vote of Hold
2025-02-18 03:26:18
I know it's probably hard to prove, but the according sticker sheet has 5 black Train logos. If we assume only one side is stickered, this leaves 2 spares (1 for the 1x8 brick, 1 for each of the 2 signs).
I think it was intended for this part to be stickered on both sides (also probably looks better).
made the following comment.
2025-02-18 06:46:14
And which set is that?
The sticker summary page is unclear.
Vincent Messenet [Cheenzo]
2025-02-18 07:48:09
According to BL 168265 sticker sheet is for sets 4525 and 4544 but none of them seem to contain this roadsign...
Rene Rechthaler [Blechtaler]
2025-02-18 11:04:04
this shortcut is this BL part:
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x53pb01#T=C&C=1
Set 4554 with sticker sheet 164555
-> this shortcut should use 164555a.dat
https://library.ldraw.org/parts/39779
even BL isnt sure if 1 or 2 stickers...
edited the part header.
2025-02-18 11:08:16
Header Edits
keywords:
to
Bricklink x53pb01, set 4554, Metro station
description:
Roadsign Wide Rectangle with Sticker Black Train Logo
to
Comment:
2025-02-18 16:16:06
So, wrong sticker used.
2025-02-19 14:24:25
Reference corrected
2025-02-19 16:19:23
Header Edits
description:
to
Comment:
posted a vote of Certify
2025-02-19 17:28:15
much better, now its linked in the right sticker sheet page
2025-02-19 20:27:14
Still think it's better if it had both sides stickered.
2025-02-19 21:02:08
backside of the sign isnt "visible" and at the border of the model:
http://www.peeron.com/scans/4554-1/23
2025-04-26 12:03:21
Massimo Maso [Sirio]
2026-04-29 17:22:32
2026-05-08 21:13:13
Header Edits
keywords:
to
9V Trains, Set 4554, Metro Station
Comment:
2026-05-08 21:13:21
Duh... I still think it should be on both sides, but since there's virtually no evidence of this besides the sticker sheet itself, I'll give in.
2026-05-08 22:24:26
And - nope.
Wrong aticker used. This should use one from sheet 164555.
2026-05-08 22:28:06
Also the BL link is wrong. Should be x53pb01. RB doesn't list stickered parts anyways, but the correct sheet is 164555 on RB.
2026-05-08 22:33:54
ok, fixed it.
2026-05-08 22:35:14
links still not working perfectly (as RB seems to overwrite it), but at least a bit better.
This part is copyright © J.C. Tchang
LDraw.org Parts Tracker, Orion Pobursky, Massimo Maso, Chris Böhnke
