Unofficial File parts/6221654pc01.dat
Part Attributes: Base Part: 6221654p.dat
Sticker  1.9 x  1.8 with Ferrari Logo and White 63 on Green Square and White Stripes on Red Background Left (Formed)
0 Sticker 1.9 x 1.8 with Ferrari Logo and White 63 on Green Square and White Stripes on Red Background Left (Formed) 0 Name: 6221654pc01.dat 0 Author: Massimo Maso [Sirio] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS 2017, 488, 63, BrickLink 75886stk01, Brickowl 731696 0 !KEYWORDS Christina Nielsen, Corsa, Ferrari, GT3, IMSA, Rebrickable 37800 0 !KEYWORDS Scuderia, Set 75886, Speed Champions
1 16 0 -15.6524 12.616 1 0 0 0 .998894 -.047023 0 .047023 .998894 s\6221654ps01.dat 1 16 0 -15.6524 12.616 1 0 0 0 .989715 -.143056 0 .143056 .989715 s\6221654ps02.dat 1 16 0 -12.8827 -1.648 1 0 0 0 .971148 -.238478 0 .238478 .971148 s\6221654ps03.dat 1 16 0 -12.8827 -1.648 1 0 0 0 .941616 -.336689 0 .336689 .941616 s\6221654ps04.dat 1 16 0 -7.5316 -14.436 1 0 0 0 .900072 -.435742 0 .435742 .900072 s\6221654ps05.dat 1 16 0 -7.5316 -14.436 1 0 0 0 .844289 -.535889 0 .535889 .844289 s\6221654ps06.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\15068b01.dat
    Line 13: 1 16 0 -15.6524 12.616 1 0 0 0 .998894 -.047023 0 .047023 .998894 s\6221654ps01.dat
    Line 14: 1 16 0 -15.6524 12.616 1 0 0 0 .989715 -.143056 0 .143056 .989715 s\6221654ps02.dat
    Line 15: 1 16 0 -12.8827 -1.648 1 0 0 0 .971148 -.238478 0 .238478 .971148 s\6221654ps03.dat
    Line 16: 1 16 0 -12.8827 -1.648 1 0 0 0 .941616 -.336689 0 .336689 .941616 s\6221654ps04.dat
    Line 17: 1 16 0 -7.5316 -14.436 1 0 0 0 .900072 -.435742 0 .435742 .900072 s\6221654ps05.dat
    Line 18: 1 16 0 -7.5316 -14.436 1 0 0 0 .844289 -.535889 0 .535889 .844289 s\6221654ps06.dat
None
2024-02-27 21:14:48
Orion Pobursky [OrionP]
made the following comment.
2024-02-27 21:17:59
The word "Pattern" in the description is needed to get this part past part submission. It will be removed once I correct the bug in the part check routine.
2024-02-27 21:17:59
This is obvious that it is not a pattern.
There is a problem in uploading the file that Orion is working on.
Even if you change the header after loading, you can't remove the word "Pattern" from the description
edited the part header.
2026-03-02 22:05:33
Header Edits
description:
Sticker 1.9 x 1.8 with Ferrari Logo and White 63 on Green Square and White Stripes on Red Background Left (Formed) Pattern
to
Comment:
