Unofficial File parts/25269p0b.dat
Part Attributes: Base Part: 25269.dat
Tile  1 x  1 Corner Round with Super Mario Pixelated Super Mushroom Pattern
0 Tile 1 x 1 Corner Round with Super Mario Pixelated Super Mushroom Pattern 0 Name: 25269p0b.dat 0 Author: Florent Faramond [Makou] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink 25269pb013, Rebrickable 25269pr0026, Set 71374 0 !HISTORY 2024-05-24 [Cheenzo] Removed unnecessary vertices 0 !HISTORY 2024-12-31 [ejboer] Closed gaps 0 !HISTORY 2025-05-30 [ejboer] Changed pattern
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\25269s01.dat 1 16 -10 0 10 0 0 20 0 1 0 -20 0 0 1-4ering.dat 4 4 -3.9 0 1 -7.0113 0 -2.1113 -3.9 0 -5.2225 -.7887 0 -2.1113 4 4 -.7887 0 -2.1113 -3.9 0 -5.2225 -2.9101 0 -6.2125 .2012 0 -3.1012 4 4 -4.8899 0 1.9899 -8.0012 0 -1.1213 -7.0113 0 -2.1113 -3.9 0 1 4 4 -2.9101 0 1.9899 -3.9 0 1 -.7887 0 -2.1113 .2012 0 -1.1213 4 4 -7.0113 0 -2.1113 -8.0012 0 -3.1012 -4.8899 0 -6.2125 -3.9 0 -5.2225 4 4 5.8393 0 5.1899 6.9 0 4.2 8.8799 0 6.1799 6.9 0 8.1598 3 4 6.9 0 8.1598 5.8393 0 7.0991 5.8393 0 5.1899 4 4 -5.0518 0 8.0494 -6.0418 0 7.0594 -3.9912 0 5.0088 -3.0012 0 5.9988 4 4 .1101 0 9.1101 -3.0012 0 5.9988 -2.0113 0 5.0088 1.1 0 8.1201 4 15 .2375 0 -5.1375 1.2049 0 -6.1049 4.142 0 -4.142 6.3406 0 1.1594 3 15 6.3406 0 1.1594 4.142 0 -4.142 7.1464 0 .3536 4 4 6.3406 0 1.1594 7.1464 0 .3536 8.478 0 2.346 8.7328 0 3.6275 4 4 -2.346 0 -8.478 1.2049 0 -6.1049 .2375 0 -5.1375 -3.1564 0 -8.6392 4 16 6.9 0 4.2 6.3406 0 1.1594 8.7328 0 3.6275 8.8799 0 6.1799 3 16 10 0 10 8.8799 0 6.1799 8.7328 0 3.6275 3 16 10 0 10 6.9 0 8.1598 8.8799 0 6.1799 4 16 1 0 10 .1101 0 9.1101 1.1 0 8.1201 4.7787 0 8.1598 4 4 2.7988 0 6.1799 4.7787 0 4.2 5.8393 0 5.1899 4.7787 0 8.1598 3 4 4.7787 0 8.1598 5.8393 0 5.1899 5.8393 0 7.0991 3 16 6.9 0 8.1598 4.7787 0 8.1598 5.8393 0 7.0991 4 16 6.9 0 4.2 5.8393 0 5.1899 4.7787 0 4.2 6.3406 0 1.1594 4 16 10 0 10 1 0 10 4.7787 0 8.1598 6.9 0 8.1598 4 16 2.7988 0 6.1799 4.7787 0 8.1598 1.1 0 8.1201 -2.0113 0 5.0088 4 16 4.7787 0 4.2 2.7988 0 6.1799 -2.0113 0 5.0088 -2.9101 0 1.9899 4 16 4.7787 0 4.2 -2.9101 0 1.9899 .2012 0 -1.1213 6.3406 0 1.1594 4 16 -2.0113 0 5.0088 -3.0012 0 5.9988 -3.9912 0 5.0088 -2.9101 0 1.9899 4 16 -4.8899 0 1.9899 -3.9 0 1 -2.9101 0 1.9899 -3.9912 0 5.0088 3 16 -5.0811 0 10 -10 0 10 -6.0418 0 9.0393 4 16 -6.0418 0 7.0594 -5.0518 0 8.0494 -6.0418 0 9.0393 -10 0 10 4 16 -6.0418 0 7.0594 -10 0 10 -8.0012 0 -1.1213 -4.8899 0 1.9899 3 16 -6.0418 0 7.0594 -4.8899 0 1.9899 -3.9912 0 5.0088 4 16 -8.0012 0 -1.1213 -10 0 10 -10 0 -10 -8.0012 0 -3.1012 3 16 -8.0012 0 -1.1213 -8.0012 0 -3.1012 -7.0113 0 -2.1113 4 16 -4.8899 0 -6.2125 -8.0012 0 -3.1012 -10 0 -10 -3.1564 0 -8.6392 4 16 -2.9101 0 -6.2125 -3.9 0 -5.2225 -4.8899 0 -6.2125 -3.1564 0 -8.6392 4 16 .2012 0 -1.1213 -.7887 0 -2.1113 .2012 0 -3.1012 6.3406 0 1.1594 4 16 .2375 0 -5.1375 6.3406 0 1.1594 .2012 0 -3.1012 -2.9101 0 -6.2125 3 16 .2375 0 -5.1375 -2.9101 0 -6.2125 -3.1564 0 -8.6392 4 4 -5.0811 0 10 -6.0418 0 9.0393 -5.0518 0 8.0494 .1101 0 9.1101 3 4 1 0 10 -5.0811 0 10 .1101 0 9.1101 3 4 .1101 0 9.1101 -5.0518 0 8.0494 -3.0012 0 5.9988
None
Part Author
2023-12-01 13:52:11
posted a vote of Hold
2023-12-06 21:46:15
Well, it might be called pixelated, but the pattern should be simplified so that all the vertices inside the coloured areas are removed
Rene Rechthaler [Blechtaler]
made the following comment.
2023-12-06 21:51:30
this issue is at all the pixelated Mario prints...
Vincent Messenet [Cheenzo]
2024-05-24 21:34:22
Evert-Jan Boer [ejboer]
Part Reviewer
posted a vote of Certify
2024-12-31 15:54:38
2024-12-31 16:35:15
small gaps due to vertex mismatch
for example
-6.11 0 -7.32
-6.11091 0 -7.32412
Part Reviewer
2024-12-31 16:42:20
closed gaps
2025-05-21 13:00:16
*Lower right spot is clearly one "pixel" too far left. Upper right one maybe too
*Missing border print offset at round edge
Part Reviewer
2025-05-30 07:51:18
Changed the pattern to match the part I have, also compated to bricklink picture, looks ok to me
This part is copyright © Florent Faramond
LDraw.org Parts Tracker, Vincent Messenet, Evert-Jan Boer
