Unofficial File parts/3004d06.dat
Part Attributes: Base Part: 3004.dat
Brick  1 x  2 with Fire Logo Centre Sticker
0 Brick 1 x 2 with Fire Logo Centre Sticker 0 Name: 3004d06.dat 0 Author: Evert-Jan Boer [ejboer] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Sticker Shortcut 0 !KEYWORDS Bricklink 3004pb024, Set 4025, Set 6685
1 16 0 0 0 1 0 0 0 1 0 0 0 1 3004.dat 1 0 0 12 -10 1 0 0 0 0 -1 0 1 0 197885d.dat
Not releaseable Errors Found (CCHHHN) Errors Found (CCHHHN)
  • Ensure stickers that are not color 16 are applied to defined transparent surfaces
User Vote
OrionP Hold
GeraldLasser Certify
RainbowDolphin Certify
Blechtaler Hold
KnightOfTarenta Hold
Part Reviewer
2023-11-19 19:55:20
Gerald Lasser [GeraldLasser]
posted a vote of Hold
2023-11-20 12:07:12
Flat sticker on flat surface is not used anymore, see Library specs:
The shortcut may not be a flat sticker on the flat surface of the part unless that surface is not parallel with one of the 3 cardinal planes (X,Y,Z). Existing sticker shortcuts that do not conform to this rule can remain in the Official Library and not be made obsolete.
posted a vote of Certify
2024-05-14 15:23:53
The regulation has been changed recently and hold reason is gone.
2024-05-15 11:03:25
edited the part header.
2024-05-17 16:57:20
Header Edits
description:
Brick 1 x 2 with Fire Logo Sticker
to
Comment:
Orion Pobursky [OrionP]
2024-05-18 04:21:01
Header Edits
category:
Brick
to
Sticker Shortcut
Comment:
2025-03-07 13:21:11
Something about this is still wrong.
The sticker sheet page for 197885/4020 lists this, despite not appearing in 4020. On the other hand it is missing from 4025, where it actually belongs (missing sticker alias?).
Also I am a bit sceptical about which stickers are truely identical across sets in this case. Looking at photos/scans from complete sheets, there are at least 2 variants: With black gaps between the flames and without.
Also the sizes seem to either be different or wrong in this case. Photos show the sticker not going all up to the edge.
Rene Rechthaler [Blechtaler]
2025-03-07 14:35:54
looks like the sticker should be more like 1x1...
also why is the sticker base black?
Javier Orquera [kuramapika1]
Part Author
made the following comment.
2025-03-07 20:03:08
2025-09-13 17:40:03
Sticker should be color 16
