Unofficial File parts/s/23801s03.dat
~Technic Steering Wheel Bearing with 2 Pegholes and 2 Axleholes Arms Centre
0 ~Technic Steering Wheel Bearing with 2 Pegholes and 2 Axleholes Arms Centre 0 Name: s\23801s03.dat 0 Author: Jens Brühl [jb70] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2022-09-15 [PTadmin] Official Update 2022-05 0 !HISTORY 2023-10-05 [jb70] subfiled from 23801.dat by Philippe Hurbain [Philo] 0 !HISTORY 2023-11-13 [jb70] Using Hi-Res Primitives on outer Ring
5 24 0 12 -19 0 14 -22 4.592 11.087 -19 -4.592 11.087 -19 5 24 0 -12 -19 0 -14 -22 4.592 -11.087 -19 -4.592 -11.087 -19 5 24 0 28 -18 0 28.587 -9 3.731 28.341 -9 -3.731 28.341 -9 5 24 0 -28.588 -9 0 -28.001 -18 3.654 -27.759 -18 -3.655 -27.76 -18 5 24 0 -25 -30 0 -25 -9 -9.568 -23.098 -30 9.567 -23.097 -30 5 24 0 14 -22 0 14 -30 -5.358 12.934 -30 5.358 12.934 -30 5 24 0 -14 -30 0 -14 -22 -5.358 -12.934 -30 5.358 -12.934 -30 1 16 0 0 -30 16.8 0 0 0 0 16.8 0 15 0 4-4cyli.dat 1 16 0 0 -30 28 0 0 0 0 28 0 12 0 48\4-4cyli.dat 1 16 0 0 -30 2 0 0 0 0 2 0 1 0 4-4ring13.dat 1 16 0 0 -30 1 0 0 0 0 1 0 1 0 4-4ring25.dat 1 16 0 0 -30 28 0 0 0 0 28 0 1 0 48\4-4aring.dat 1 16 0 0 -30 28 0 0 0 0 28 0 1 0 48\4-4edge.dat 1 16 0 0 -30 16.8 0 0 0 0 16.8 0 1 0 4-4edge.dat 1 16 0 20 0 1 0 0 0 -1 0 0 0 1 connhol3.dat 1 16 0 29.5 0 9 0 0 0 .5 0 0 0 9 4-4cyli.dat 1 16 0 27 0 9 0 0 0 2.5 0 0 0 9 2-4cyli.dat 1 16 0 12 0 9 0 0 0 15 0 0 0 9 2-4cyli.dat 1 16 0 30 0 9 0 0 0 1 0 0 0 9 4-4edge.dat 1 16 0 29.5 0 9 0 0 0 1 0 0 0 -9 2-4edge.dat 1 16 0 29.5 0 9 0 0 0 -1 0 0 0 -9 2-4ndis.dat 1 16 0 12 0 8.31492 0 -3.44415 0 1 0 3.44415 0 8.31492 3-8edge.dat 1 16 0 12 0 -8 0 0 0 1 0 0 0 -8 2-4ndis.dat 1 16 0 12 0 2 0 0 0 1 0 0 0 2 4-4ring3.dat 1 16 0 12 0 .92388 0 -.38268 0 1 0 .38268 0 .92388 3-8ring8.dat 1 16 0 -27 0 9 0 0 0 -3 0 0 0 9 4-4cyli.dat 1 16 0 -12 0 9 0 0 0 -15 0 0 0 9 2-4cyli.dat 1 16 0 -30 0 9 0 0 0 -1 0 0 0 9 4-4edge.dat 1 16 0 -12 0 8.31492 0 -3.44415 0 -1 0 3.44415 0 8.31492 3-8edge.dat 1 16 0 -12 0 -8 0 0 0 -1 0 0 0 -8 2-4ndis.dat 1 16 0 -12 0 2 0 0 0 -1 0 0 0 2 4-4ring3.dat 1 16 0 -12 0 .92388 0 -.38268 0 -1 0 .38268 0 .92388 3-8ring8.dat 1 16 0 -25 0 -8.31492 0 3.44415 0 11 0 -3.44415 0 -8.31492 3-8cyli.dat 1 16 0 24.512 -30 -2.5 0 0 0 0 -2.5 0 -1 0 2-4edge.dat 1 16 0 24.512 -30 -2.5 0 0 0 0 -2.5 0 1 0 2-4disc.dat 3 16 2.5 24.512 -30 -2.5 24.512 -30 0 25 -30 1 16 0 24.512 -30 -2.5 0 0 0 0 -2.5 0 22 0 2-4cyli.dat 1 16 0 0 -15 11.8794 0 -11.8794 11.8794 0 11.8794 0 8.7 0 1-4cyli.dat 1 16 0 14 0 -8.31492 0 3.44415 0 11 0 -3.44415 0 -8.31492 3-8cyli.dat 1 16 0 0 -15 6.42908 0 -15.5212 -15.5212 0 -6.42908 0 8.7 0 1-8cyli.dat 1 16 0 -20 0 -1 0 0 0 1 0 0 0 1 connhol3.dat
User Vote
Holly-Wood Certify
Jens Brühl [jb70]
Part Author
2023-10-05 20:11:47
Subfile structure modified to be reused with 65766.dat
made the following comment.
2023-11-08 17:47:53
Maybe this could be reworked to use hi-res on the outer ring?
Jens Brühl [jb70]
Part Author
2023-11-09 22:31:19
Used Hi Res Primitives for outer ring
posted a vote of Hold
2023-11-12 16:54:14
Maybe you can get the inside of the outer ring to work too?
The added 48\4-4aring doesn't work.
Jens Brühl [jb70]
Part Author
2023-11-12 23:38:07
Fixed issues with gaps between faces and primitives on the inside.
Orion Pobursky [OrionP]
2024-03-23 00:59:43
Update ring primitives via script. This will not reset the vote status of the part.
edited the part header.
2025-10-23 07:26:42
Header Edits
help:
0 !HELP
to
0 !HELP
keywords:
Porsche 911 GT3 RS, set 42056
to
description:
~Technic Steering Wheel Bearing with 2 Pegholes & 2 Axleholes Arms Center
to
~Technic Steering Wheel Bearing with 2 Pegholes and 2 Axleholes Arms Center
Comment:
Peter Blomberg [WUIt]
2025-10-23 23:12:29
Australian English required: Center should be Centre.
Jens Brühl [jb70]
Part Author
2025-10-24 17:10:41
Header Edits
Rene Rechthaler [Blechtaler]
2025-10-24 17:18:29
why the hi-res rin13?
1 16 0 0 -30 2 0 0 0 0 2 0 1 0 48\4-4rin13.dat
1 16 0 0 -30 1 0 0 0 0 1 0 1 0 4-4rin25.dat
1 16 0 0 -30 26 0 0 0 0 26 0 1 0 48\4-4aring.dat
2 normal res rings and the aring at the outside would result in slightly less quads (and rin prims are obsolete, both exist as normal res ring prim)
Jens Brühl [jb70]
Part Author
2025-10-26 15:38:54
Removed high res from ring13
Willy Tschager [Holly-Wood]
posted a vote of Certify
2026-07-02 09:24:09
This part is copyright © Jens Brühl
