Unofficial File parts/32333.dat
View official version of part
Technic Brick  5 x  3 x  1 with  8 Pegholes and  2 Studs
0 Technic Brick 5 x 3 x 1 with 8 Pegholes and 2 Studs 0 Name: 32333.dat 0 Author: Marc Klein [marckl] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS block, connector, Engine, Housing 0 !HISTORY 2023-02-02 [guyvivan] Made BFC compliant & Move 0 Origine 0 !HISTORY 2023-02-02 [guyvivan] Add Missing edge 0 !HISTORY 2023-02-02 [PTadmin] Official Update 2013-02 0 !HISTORY 2023-02-02 [Cheenzo] Created subparts and fixed stud3a position
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\32333s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\32333s01.dat 1 16 10 0 0 1 0 0 0 1 0 0 0 1 stud2.dat 1 16 -10 0 0 1 0 0 0 1 0 0 0 1 stud2.dat 0 BFC INVERTNEXT 1 16 0 10 8 -6 0 0 0 0 -6 0 -16 0 4-4cyli.dat 1 16 0 10 10 -1 0 0 0 0 -1 0 -1 0 4-4ring8.dat 1 16 0 10 10 -1 0 0 0 0 1 0 -1 0 peghole.dat 1 16 0 10 -10 1 0 0 0 0 -1 0 1 0 4-4ring8.dat 1 16 0 10 -10 1 0 0 0 0 1 0 1 0 peghole.dat 1 16 0 56.8 0 1 0 0 0 -1.8 0 0 0 1 stud3a.dat 0 BFC INVERTNEXT 1 16 0 50 8 -6 0 0 0 0 -6 0 -16 0 4-4cyli.dat 1 16 0 50 10 -1 0 0 0 0 1 0 -1 0 peghole.dat 1 16 0 50 -10 1 0 0 0 0 1 0 1 0 peghole.dat
None
Vincent Messenet [Cheenzo]
2023-02-10 04:45:09
2023-02-10 05:16:42
Test submit
2023-02-10 05:17:54
Test submit
posted a vote of Hold
2023-02-20 18:08:29
The cavities in the top beam should use npeghol primitives.
Lots of overlapping surfaces and T-junctions.
2023-03-06 08:07:21
made the following comment.
2023-03-06 08:09:39
I could not find any npeghol primitive fitting this part. Can you please advise which one(s) should be used?
posted a vote of Certify
2023-03-19 21:41:02
Gerald Lasser [GeraldLasser]
2024-11-20 23:01:45
The two cyli added here are bleeding through the surface partially:
replace:
1 13 0 50 10 -8.30974 0 3.44201 -3.44201 0 -8.30974 0 -20 0 3-8cyli.dat
1 13 0 50 10 -6.36 0 6.36 -6.36 0 -6.36 0 -1 0 1-4edge.dat
1 13 0 50 -10 -6.36 0 6.36 -6.36 0 -6.36 0 -1 0 1-4edge.dat
with
1 13 0 50 10 0 0 -9 -9 0 0 0 -20 0 1-8cylo.dat
1 13 0 50 10 0 0 9 -9 0 0 0 -20 0 1-8cylo.dat
plus the two quads to complete the bow, half of this could be added also in s01,
don't forget the complementary cond.
same at the top, bleeding clyi.
replace
1 13 0 10 10 6.36396 0 6.36396 -6.36396 0 6.36396 0 -20 0 3-4cyli.dat
1 13 0 10 -10 6.36396 0 -6.36396 6.36396 0 6.36396 0 1 0 1-4edge.dat
1 13 0 10 10 6.36396 0 -6.36396 6.36396 0 6.36396 0 1 0 1-4edge.dat
either here with (or in s01)
1 13 0 10 10 0 0 -9 9 0 0 0 -20 0 1-8cylo.dat
1 13 0 10 10 0 0 9 9 0 0 0 -20 0 1-8cylo.dat
rest follows in s02
2025-07-18 07:05:01
Fixed bleeding issues
This part is copyright © Marc Klein
LDraw.org Parts Tracker, Guy Vivan, Vincent Messenet
