Unofficial File parts/s22.dat
Sticker 1.8 x 1.8 with Bar Code and Time Block
0 Sticker 1.8 x 1.8 with Bar Code and Time Block 0 Name: s22.dat 0 Author: Javier Orquera [kuramapika1] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Bar Code, Mario, Rebrickable u-unknown, Scanner Code, Set 71365 0 !KEYWORDS Set 71369, Super Mario
0 !TEXMAP START PLANAR -20 0 20 20 0 20 -20 0 -20 s22.png 0 !: 1 16 0 0 0 1 0 0 0 1 0 0 0 -1 s\sticker_templates01.dat 0 !TEXMAP FALLBACK 1 16 0 0 0 1 0 0 0 1 0 0 0 -1 s\sticker_templates01.dat 0 !TEXMAP END 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\sticker_templates02.dat
Not releaseable Errors Found (HN) Errors Found (HN)
User Vote
Holly-Wood Hold
Part Author
2023-02-06 18:39:10
Willy Tschager [Holly-Wood]
posted a vote of Hold
2023-02-06 21:30:28
* Texture missing
Part Author
made the following comment.
2023-02-06 21:49:53
Yes, because there's a problem with submiting the image. See this: https://forums.ldraw.org/thread-27084.html
Part Author
2023-02-16 14:00:25
It is good to do the KEYWORDS command in this file or I need to move it to the main 3068 (respective) file? I ask because I don't want to correct 150+ files.
Orion Pobursky [OrionP]
2023-02-16 16:02:48
Each individual sticker needs, at a minimum, a set keyword. It also helps to have the BL, RB numbers for the sticker sheet.
Jeff Jones [notmaster]
2025-05-31 17:16:07
texture no longer missing
lift hold?
2025-06-05 14:05:53
* ONE generic sticker without a texture should be used for all. The rest deleted.
Rene Rechthaler [Blechtaler]
2025-06-05 15:20:05
at least the sticker types could be kept?
(fully colored corner like here or just a symbol cutout in the stripes)
This part is copyright © Javier Orquera
