Unofficial File parts/53923.dat
Hinge Arm Locking with Single Finger and Axlehole without Slots
0 Hinge Arm Locking with Single Finger and Axlehole without Slots 0 Name: 53923.dat 0 Author: Max Martin Richter [MMR1988] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS click-hinge, Life on Mars, Star Wars, Studio, Technic 0 !HISTORY 2024-03-23 [OrionP] Updated ring primitives
1 16 0 0 0 1 0 0 0 1 0 0 0 1 clh3.dat 1 16 0 0 0 8.316 0 -3.444 -3.444 0 -8.315 0 1 0 3-8edge.dat 1 16 0 0 0 -8.316 0 3.444 3.444 0 8.315 0 1 0 3-8edge.dat 1 16 0 0 0 1 0 0 0 0 1 0 -1 0 axl3end.dat 1 16 0 0 0 2.77164 0 -1.14805 -1.14805 0 -2.77164 0 1 0 3-8ring2.dat 1 16 0 0 0 -2.77164 0 1.14805 1.14805 0 2.77164 0 1 0 3-8ring2.dat 1 16 0 0 0 1 0 0 0 0 1 0 20 0 axl3hole.dat 1 16 0 0 2.875 2.25 0 0 0 0 2.25 0 -1 0 4-4ring3.dat 1 16 0 0 17.125 2.25 0 0 0 0 2.25 0 1 0 4-4ring3.dat 1 16 0 0 20 3 0 0 0 0 3 0 -1 0 4-4ring2.dat 1 16 0 0 0 9 0 0 0 0 9 0 2.875 0 4-4cyli.dat 1 16 0 0 20 9 0 0 0 0 9 0 -2.875 0 4-4cylo.dat 1 16 0 0 2.875 9 0 0 0 0 9 0 -1 0 4-4edge.dat 1 16 0 0 2.875 8.5 0 0 0 0 8.5 0 2.85 0 4-4cylo.dat 1 16 0 0 5.725 9 0 0 0 0 9 0 2.85 0 4-4cylo.dat 1 16 0 0 8.575 8.5 0 0 0 0 8.5 0 2.85 0 4-4cylo.dat 1 16 0 0 11.425 9 0 0 0 0 9 0 2.85 0 4-4cylo.dat 1 16 0 0 14.275 8.5 0 0 0 0 8.5 0 2.85 0 4-4cylo.dat 1 16 0 0 5.725 -.5 0 0 0 0 .5 0 1 0 4-4ring17.dat 1 16 0 0 8.575 -.5 0 0 0 0 .5 0 -1 0 4-4ring17.dat 1 16 0 0 11.425 -.5 0 0 0 0 .5 0 1 0 4-4ring17.dat 1 16 0 0 14.275 -.5 0 0 0 0 .5 0 -1 0 4-4ring17.dat
Not releaseable Errors Found (CHN) Errors Found (CHN)
User Vote
Holly-Wood Hold
fwcain Certify
2021-12-30 21:55:02
made the following comment.
2021-12-30 22:00:01
I sent an updated version of clh3 to our admin to avoid the edge and bleed-in at the inner axle end.
Orion Pobursky [OrionP]
2024-03-23 00:59:38
Update ring primitives via script. This will not reset the vote status of the part.
Franklin W. Cain [fwcain]
Part Reviewer
posted a vote of Certify
2024-03-25 21:29:56
Willy Tschager [Holly-Wood]
posted a vote of Hold
2024-03-28 09:09:01
* The difference between this and:
30552 - Hinge Cylinder 1 x 2 Locking with 1 Finger and Axle Hole on Ends with Slots
https://www.bricklink.com/v2/catalog/catalogitem.page?P=30552#T=C
is not only the missing slot, but also that the slit on the top is larger as in clh2.dat - https://library.ldraw.org/official/22131. This calls for a new prim.
Check:
https://rebrickable.com/parts/53923/hinge-cylinder-1-x-2-locking-with-1-finger-and-axle-hole-on-ends-no-side-slots/
2024-04-27 06:41:22
I checked several pictures from different sources in the internet and can't find a difference between these clips. :-(
2024-05-01 19:09:56
Ok, spotted the difference. this part needs to be fixed...
2024-05-01 19:15:10
Actually there is no prim for this part. I'll do one, when I'm in the mood for it.
This part is copyright © Max Martin Richter
