Unofficial File parts/53407c02.dat
Base Part: 53407.dat
0 Train Track 6 Studs Wide Switch Point Left (Branching)
0 Name: 53407c02.dat
0 Author: Jens Brühl [jb70]
0 !HISTORY 2020-12-17 [jb70] Used Left Hand parts 2862b.dat and 2939.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 53407c00.dat
1 16 -170 0 -37 1 0 0 0 1 0 0 0 1 2862b.dat
1 16 -250 0 60.75 0 0 1 0 1 0 1 0 0 2864.dat
1 14 -250 -24 170 -1 0 0 0 .883 .469 0 -.469 .883 2866.dat
Needs 2 More Votes (N)
Has Uncertified Subfilesparts/2862b.dat (Needs 1 More Vote)
parts/53407c00.dat (Needs 2 More Votes)
parts/2860b.dat (Errors Found)
parts/53407.dat (Needs 2 More Votes)
parts/s/53404s01.dat (Needs 2 More Votes)
parts/s/53404s02.dat (Needs 2 More Votes)
parts/s/53404s03.dat (Needs 2 More Votes)
parts/s/53404s04.dat (Needs 2 More Votes)
parts/s/53404s05.dat (Needs 2 More Votes)
None
Jens Brühl [jb70]
2020-12-15 22:15:01
I hope, the part numbering for the assemblies is OK. I took the numbering scheme from the last changes to the 12V switches 73697ac01.dat.
Jens Brühl [jb70]
2020-12-17 16:45:01
Rene Rechthaler [Blechtaler]
made the following comment.
2025-04-28 19:15:45
bottom plate got shifted
Jens Brühl [jb70]
2025-06-08 16:00:32
Changed bottom level from 4 LDU to 2.5 LDU to be compatible with the new bottom plates 2863.dat and 2939.dat.
Jens Brühl [jb70]
2025-08-24 21:08:22
Pivot Point for the Lever (2866) moved to 24 above ground.
2025-08-25 15:18:10
Partnumber is wrong. Think this should be 53406c01-f2
This part is copyright ©
Jens Brühl
Licensed under
CC BY 4.0
