Unofficial File parts/53407c01.dat
Part Attributes: Base Part: 53407.dat
Train Track 6 Studs Wide Switch Point Left (Straight)
0 Train Track 6 Studs Wide Switch Point Left (Straight) 0 Name: 53407c01.dat 0 Author: Jens Brühl [jb70] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2020-12-17 [jb70] Used Left Hand parts 2862b.dat and 2939.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 53407c00.dat 1 16 -170 0 -37 .99518 0 .09802 0 1 0 -.09802 0 .99518 2862b.dat 1 16 -250 0 72.75 0 0 1 0 1 0 1 0 0 2864.dat 1 14 -250 -24 170 -1 0 0 0 .883 .469 0 .469 -.883 2866.dat
None
Jens Brühl [jb70]
Part Author
2020-12-15 22:15:01
I hope, the part numbering for the assemblies is OK. I took the numbering scheme from the last changes to the 12V switches 73697ac01.dat.
Jens Brühl [jb70]
Part Author
2020-12-17 16:45:01
Jens Brühl [jb70]
Part Author
2025-06-08 16:00:32
Changed bottom level from 4 LDU to 2.5 LDU to be compatible with the new bottom plates 2863.dat and 2939.dat.
Jens Brühl [jb70]
Part Author
2025-08-24 21:08:22
Pivot Point for the Lever (2866) moved to 24 above ground.
made the following comment.
2025-08-25 15:17:54
Partnumber is wrong. Think this should be 53406c01-f1
This part is copyright © Jens Brühl
