Unofficial File parts/4622098a.dat
Sticker  3.3 x  1.3 with Square Connections with Vents on Blue Background
0 Sticker 3.3 x 1.3 with Square Connections with Vents on Blue Background 0 Name: 4622098a.dat 0 Author: Alex Herrera [alanbrito98] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink 7962stk01, Brickowl 968771, Episode I, pod racer 0 !KEYWORDS Rebrickable 95687, Set 7962, Star Wars, The Phantom Menace 0 !HISTORY 2025-11-08 [MagFors] Stretched to match formed sticker
1 16 0 0 0 0 0 1 0 1 0 -1 0 0 s\stickerback013x033.dat 0 // Pattern 1 1 11 -.25 31.5 1.5 0 0 0 1 0 0 0 1.5 1-4disc.dat 1 1 -11 -.25 -31.5 -1.5 0 0 0 1 0 0 0 -1.5 1-4disc.dat 1 1 11 -.25 -31.5 1.5 0 0 0 1 0 0 0 -1.5 1-4disc.dat 1 1 -11 -.25 31.5 -1.5 0 0 0 1 0 0 0 1.5 1-4disc.dat 3 0 -2.36 -.25 26.86 -.18 -.25 23.66 6.38 -.25 26.86 3 0 11 -.25 -14.43 7.04 -.25 -15.21 10.21 -.25 -15.21 3 0 11 -.25 -14.43 6.28 -.25 -15.21 7.04 -.25 -15.21 4 0 10.21 -.25 -15.21 10.21 -.25 -24.87 11 -.25 -31.5 11 -.25 -14.43 4 0 7.81 -.25 -24 6.28 -.25 -26.86 11 -.25 -31.5 10.21 -.25 -24.87 3 0 -2.46 -.25 -26.86 -8.69 -.25 -23.66 -11 -.25 -31.5 3 0 -2.46 -.25 -15.21 -11.02 -.25 -14.43 -9.45 -.25 -15.21 4 0 -11.02 -.25 -14.43 -2.46 -.25 -15.21 -.93 -.25 -15.21 11 -.25 -14.43 3 0 -2.36 -.25 26.86 -11 -.25 31.5 -8.59 -.25 23.66 3 0 6.28 -.25 -26.86 -.28 -.25 -23.66 -2.46 -.25 -26.86 3 0 11 -.25 -14.43 -.93 -.25 -15.21 6.28 -.25 -15.21 3 0 -2.36 -.25 15.21 -9.35 -.25 15.21 -11.02 -.25 14.4 3 0 11 -.25 14.4 6.38 -.25 15.21 -.83 -.25 15.21 4 0 7.14 -.25 15.21 7.91 -.25 24 6.38 -.25 26.86 6.38 -.25 15.21 4 0 10.31 -.25 24.87 10.31 -.25 15.21 11 -.25 14.4 11 -.25 31.5 3 0 11 -.25 14.4 7.14 -.25 15.21 6.38 -.25 15.21 4 0 7.91 -.25 24 10.31 -.25 24.87 11 -.25 31.5 6.38 -.25 26.86 3 0 11 -.25 14.4 10.31 -.25 15.21 7.14 -.25 15.21 4 0 -2.36 -.25 26.86 6.38 -.25 26.86 11 -.25 31.5 -11 -.25 31.5 4 0 6.28 -.25 -26.86 -2.46 -.25 -26.86 -11 -.25 -31.5 11 -.25 -31.5 4 0 -11.02 -.25 14.4 11 -.25 14.4 -.83 -.25 15.21 -2.36 -.25 15.21 4 0 -11.02 -.25 14.4 -9.35 -.25 15.21 -8.59 -.25 23.66 -11 -.25 31.5 4 0 -2.36 -.25 15.21 -.83 -.25 15.21 -.18 -.25 23.66 -2.36 -.25 26.86 4 0 -11 -.25 -31.5 -8.69 -.25 -23.66 -9.45 -.25 -15.21 -11.02 -.25 -14.43 4 0 6.28 -.25 -26.86 7.81 -.25 -24 7.04 -.25 -15.21 6.28 -.25 -15.21 4 0 -2.46 -.25 -26.86 -.28 -.25 -23.66 -.93 -.25 -15.21 -2.46 -.25 -15.21 4 1 12.5 -.25 31.5 11 -.25 14.4 11 -.25 -14.43 12.5 -.25 -31.5 4 1 -11 -.25 31.5 11 -.25 31.5 11 -.25 33 -11 -.25 33 4 1 11 -.25 14.4 -11.02 -.25 14.4 -11.02 -.25 -14.43 11 -.25 -14.43 3 1 -12.5 -.25 -31.5 -11 -.25 -31.5 -11.02 -.25 -14.43 3 1 12.5 -.25 31.5 11 -.25 31.5 11 -.25 14.4 3 1 12.5 -.25 -31.5 11 -.25 -14.43 11 -.25 -31.5 4 1 -11 -.25 -31.5 -11 -.25 -33 11 -.25 -33 11 -.25 -31.5 3 1 -11.02 -.25 14.4 -11 -.25 31.5 -12.5 -.25 31.5 4 1 -11.02 -.25 -14.43 -11.02 -.25 14.4 -12.5 -.25 31.5 -12.5 -.25 -31.5 4 72 -9.45 -.25 -15.21 -8.69 -.25 -23.66 -2.46 -.25 -26.86 -2.46 -.25 -15.21 4 72 -.93 -.25 -15.21 -.28 -.25 -23.66 6.28 -.25 -26.86 6.28 -.25 -15.21 3 72 -.18 -.25 23.66 6.38 -.25 15.21 6.38 -.25 26.86 4 72 10.31 -.25 24.87 7.91 -.25 24 7.14 -.25 15.21 10.31 -.25 15.21 4 72 7.81 -.25 -24 10.21 -.25 -24.87 10.21 -.25 -15.21 7.04 -.25 -15.21 4 72 -9.35 -.25 15.21 -2.36 -.25 15.21 -2.36 -.25 26.86 -8.59 -.25 23.66 3 72 -.83 -.25 15.21 6.38 -.25 15.21 -.18 -.25 23.66
Certified (ACCN) Certified (ACCN)
User Vote
OrionP Admin Review
Holly-Wood Certify
KnightOfTarenta Certify
Part Author
2022-08-13 10:00:01
Part Author
2022-09-07 22:10:01
Made changes submitted regarding sticker size and rounded courners.
Willy Tschager [Holly-Wood]
posted a vote of Hold
2025-04-09 09:34:18
* Overlap:
3 1 -11.01 -.25 13.61 -11.01 -.25 15.12 -12 -.25 15.12
4 1 -12 -.25 11.58 -12 -.25 7.82 -11.01 -.25 11.58 -11.01 -.25 15.12
3 1 -11.01 -.25 15.12 -12 -.25 15.12 -12 -.25 11.58
* Gap:
2 4 -11.01 -.25 -27.23 -12.01 -.25 -26.22
2 4 -12.01 -.25 -26.22 -11.01 -.25 -27.22
* Pattern should be subbed and reused twice
* Small box shorter than the sticker surface
* All these vertices should be merged:
2 4 -11.99 -.25 -3.94 -12.01 -.25 -26.22
2025-11-08 17:06:35
It looks like the formed sticker has a correct length, which can only mean the flat version is to short.
2025-11-08 22:19:35
Part Reviewer
2025-11-09 16:27:33
Z-position of lower right 1-4disc.dat primitve wrong:
"1 1 11 -.25 31.52 1.5 0 0 0 1 0 0 0 1.5 1-4disc.dat"
instead of
"1 1 11 -.25 31.5 1.5 0 0 0 1 0 0 0 1.5 1-4disc.dat"
2025-11-09 16:54:23
posted a vote of Certify
2026-04-26 12:51:59
2026-05-27 20:12:35
Pattern is slightly off, but not enough to cause an issue...
edited the part header.
2026-05-27 20:15:56
Header Edits
keywords:
Bricklink 7962stk01, Brickowl 968771, Rebrickable 95687, Set 7962, Star Wars
to
Set 7962, Star Wars, Episode I, Pod Racer, The Phantom Menace, Bricklink 7962stk01, Brickowl 968771, Rebrickable 95687
Comment:
Orion Pobursky [OrionP]
posted a vote of Admin Review
2026-07-08 01:23:01
This part is copyright © Alex Herrera
LDraw.org Parts Tracker, Magnus Forsberg
