Unofficial File parts/44139.dat
Constraction Rahkshi Kraata Holder
0 Constraction Rahkshi Kraata Holder 0 Name: 44139.dat 0 Author: Gerald Lasser [GeraldLasser] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP ball socket connection: 0 !HELP 1 38 0 -40 -60 -1 0 0 0 1 0 0 0 -1 32174.dat 0 !HELP back stud connection: 0 !HELP 1 4 0 -10 20 1 0 0 0 1 0 0 0 1 6141.dat 0 BFC CERTIFY CCW 0 !KEYWORDS Armor, Armour, bionicle 0 !HISTORY 2023-03-12 [SwampKryakwa] Fixed balljoint size 0 !HISTORY 2025-05-03 [notmaster] corrected origin fixed balljoint sized t juncs edgelines etc
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\44139s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\44139s01.dat 0 // Balljoint 1 16 0 -40 -40 0 12.81 0 0 0 12.81 12.81 0 0 8-8sphe.dat 4 16 5.2208 -42.7789 -30.5 5.2208 -42.7789 -9 -5.2208 -42.7789 -9 -5.2208 -42.7789 -30.5 0 // Vertical Wall and Pinhole Connector 4 16 5.2208 -42.7789 -9 8 -42.7789 -3.5 -8 -42.7789 -3.5 -5.2208 -42.7789 -9 2 24 8 -42.7789 -3.5 -8 -42.7789 -3.5 3 16 25 -19.15 -9 0 -34 -9 -25 -19.15 -9 1 16 0 -16.575 -9 0 0 25 2.575 0 0 0 1 0 rect2p.dat 4 16 10 -10 -9 25 -14 -9 -25 -14 -9 -10 -10 -9 4 16 -8 -42.7789 -3.5 8 -42.7789 -3.5 9.5675 -42.2475 -3.5 -9.5675 -42.2475 -3.5 4 16 9.5675 -42.2475 -3.5 6 -38 -3.5 -6 -38 -3.5 -9.5675 -42.2475 -3.5 4 16 -6 -38 -3.5 6 -38 -3.5 6.5 -32 -3.5 -6.5 -32 -3.5 4 16 -6.5 -32 -3.5 6.5 -32 -3.5 5.5 -14 -3.5 -5.5 -14 -3.5 0 BFC INVERTNEXT 1 16 0 -14 2 0 0 -5.5 0 4 0 5.5 0 0 box5-4a.dat 3 16 5.5 -14 8.5 0 -14 14 -5.56 -14 8.5 4 16 5.5 -14 7.5 5.5 -14 8.5 -5.56 -14 8.5 -5.5 -14 7.5 3 16 -10 -14 29.5 0 -14 26 10 -14 29.5 2 24 -5.5 -14 7.5 5.5 -14 7.5 0 BFC INVERTNEXT 1 16 0 -10 20 0 0 6 0 -4 0 6 0 0 4-4cylo.dat 1 16 0 -14 20 0 0 6 0 1 0 6 0 0 4-4ndis.dat 1 16 0 -10 20 0 0 6 0 -1 0 6 0 0 4-4ndis.dat 3 16 10 -10 9 -10 -10 9 0 -10 14 3 16 10 -10 29.5 0 -10 26 -10 -10 29.5 0 // Peghole 1 16 0 0 0 0 1 0 0 0 1 1 0 0 connhole.dat 1 16 -10 0 0 0 20 0 0 0 9 9 0 0 2-4cylo.dat 1 16 10 0 0 0 -1 0 0 0 -9 9 0 0 2-4ndis.dat 1 16 -10 0 0 0 1 0 0 0 -9 9 0 0 2-4ndis.dat 1 16 0 -4.5 -9 0 0 10 4.5 0 0 0 1 0 rect2p.dat 1 16 0 -4.5 9 0 0 -10 4.5 0 0 0 -1 0 rect2p.dat 1 16 0 -10 0 0 0 -10 0 1 0 9 0 0 box4o8a.dat 1 16 0 -10 0 10 0 0 0 1 0 0 0 9 recte3.dat 0 // Rounded Area 0 BFC INVERTNEXT 1 16 10 60 29.5 0 -20 0 -70 0 0 0 0 70 48\1-8cyli.dat 1 16 10 60 29.5 0 -20 0 -74 0 0 0 0 74 48\5-48cyli.dat 1 16 0 10.503 80.4112 10 0 0 0 -1 0 0 0 -1.4142 rect3.dat 1 16 0 6.43305 81.8254 -10 0 0 0 0 -4.06995 0 -1 0 rect.dat 4 16 14 -.2984 78.7938 10 2.3631 81.8254 -10 2.3631 81.8254 -14 -.2984 78.7938 1 16 0 -.2984 77.2813 14 0 0 0 1 0 0 0 1.5125 rect2p.dat 4 16 -14 -.2984 75.7688 -10 1.2884 74.5512 10 1.2884 74.5512 14 -.2984 75.7688 2 24 10 1.2884 74.5512 -10 1.2884 74.5512
Not releaseable Errors Found (CHN) Errors Found (CHN)
User Vote
KnightOfTarenta Hold
WUIt Certify
2020-12-08 11:25:02
My first Bionlicle part, origin is at the ball joint, alright?
2020-12-08 11:25:02
posted a vote of Hold
2020-12-08 22:05:01
Or you could have it in the connhole prim.
The radius of the ball is allways 12.81 ldu. Don't ask me why.
Why is part of this surface placed in the subfile?
1 16 10 100 69.5 0 -20 0 -74 0 0 0 0 74 48\5-48cyli.dat
made the following comment.
2020-12-08 23:35:01
I though as well about the connhole, but may be for positioning the ball joint is better.
concerning this:
I think you mean the two strips to the side of it, that's right can be in the main file, it is an editing artefact
Max Murtazin [SwampKryakwa]
Part Reviewer
2023-03-12 00:27:14
Part Reviewer
2023-05-24 13:53:48
Missing outlines between ball joint and stem connecting it to rest of the part
Jeff Jones [notmaster]
2024-07-02 09:57:15
i think origin should be at pin at bottom
2024-07-02 12:41:53
also i ran tjunctionfinder on this and it found 97 t junctions
2025-04-09 17:06:56
is the ball actually oval on the real part?
2025-04-09 17:20:29
looking at pics it doesnt look oval
maybe swamp based it on a deformed version
2025-04-09 17:21:34
2025-04-09 18:40:40
did a overhaul
https://justpaste.it/hqsxs
https://justpaste.it/77yi6
before i upload to pt just for some feedback :)
2025-04-10 08:58:09
what did you change?
The diameter of the sphere
position, anything else?
edited the part header.
2025-04-10 08:58:36
Header Edits
keywords:
Armour, bionicle, Gukko, Guurahk, Jaller, Kurahk, Lerahk, Makuta, Panrahk, Shoudler Cover, Takanuva, Turahk, Vorahk
to
Armour, Gukko, Guurahk, Jaller, Kurahk, Lerahk, Makuta, Panrahk, Shoulder Cover, Takanuva, Turahk, Vorahk, bionicle
Comment:
2025-04-10 09:43:13
a t junc that cyli you said needed work anyways some edges thats it i think?
Rene Rechthaler [Blechtaler]
2025-05-02 21:59:23
1 16 0 0 0 0 12.81 0 0 0 12 12.81 0 0 8-8sphe.dat
should be 12.81 in all directions
(and origin should be in the connhole, but add a !Help for the head and back hole)
2025-05-02 23:54:15
try to submit my changes but
it error saying meta thing
checked lines are history and help and keywords
2025-05-03 09:24:39
44139.dat: Line 8, invalid META command or comment without //
44139.dat: Line 9, invalid META command or comment without //
44139.dat: Line 13, invalid META command or comment without //
44139.dat: Line 15, invalid META command or comment without //
44139.dat: Line 16, invalid META command or comment without //
maybe something wrong with the tracker :p
2025-05-03 09:45:55
had to remove the keywords history lines and help lines so that it would be uploaded
here what it was
0 // ball socket and back stud connection
0 !KEYWORDS Armour, bionicle, Armor
2025-05-03 09:57:11
2025-05-03 09:57:35
oh wait it was the helplines that tracker didnt like
2025-05-03 12:08:05
You can't have a comment before the Help info.
Everything else should work.
Peter Blomberg [WUIt]
2025-10-18 19:11:59
Please put back the help lines with this change to the "comment line":
0 !HELP Place ball socket and back stud connectors with e.g.
2025-10-18 19:20:10
Header Edits
help:
0 !HELP
to
Comment:
hope that solves it.
posted a vote of Certify
2025-10-18 20:03:42
2026-05-01 19:29:26
Missing the support rib for the ball joint:
https://www.ebay.co.uk/itm/305481240107
LDraw.org Parts Tracker, Max Murtazin, Jeff Jones
